Old 02-23-2025, 01:56 PM   #1
1970 29' Ambassador
1978 31' Sovereign
Beautiful Santa Rosa , California
Awning sash halves spread when apart.
Hi All,
In my continuing effort to rehab the windows on our 1970 Ambassador I have found that the frame halves of the awning window next to the entry door do not form a rectangle without the steel “registration bar” is in place (the halves are just set next to each other in the frame that is riveted to the skin).
The obvious answer is to install a fairly long registration bar on both the top and bottom during reassembly to pull the shape back into the correct alignment, but I am wondering if the sash frame halves can be “encouraged” (bent slightly) back into more of a 90 degree angle, or if that comes with too many risks of its own?
David
2002sheds is offline   Reply With Quote
Old 02-26-2025, 12:32 PM   #2
1970 29' Ambassador
1978 31' Sovereign
Hi All,
Lots of views but no replies. Below are a few pictures that I hope will help.
As you can see, the frames are only slightly out of square.
David
ID:	451212   Click image for larger version
Old 03-20-2025, 02:42 PM   #3
1970 29' Ambassador
1978 31' Sovereign
Hi All,
Closing this thread. I ended up cutting longer bar stock for the upper and lower halves, and then I inserted each long piece of bar stock in one side (top and bottom) and then squeezed the other half into more of a 90 degree angle as I put the halves together.
The long bar stock did the trick of helping the frame stay more square when assembled. The sash now rests in the frame on the shell as it should.
David
Old 03-21-2025, 12:05 AM   #4
1980 24' Caravelle
vallejo , California
hey Dave,long time no read! good to see you still working on your AS. was confused until I saw the pics:single pane or double. I keep plugging away with new projects for my AS. good luck. Kurt
ke6gkv is offline   Reply With Quote
Old 03-24-2025, 05:26 AM   #5
1970 29' Ambassador
1978 31' Sovereign
Hi Kurt,
Thanks for the shout out — and I hope your projects are going well !!!
David
How do i get stack window sash apart crazycuda Windows & Screens 12 08-06-2021 08:31 PM
Gotta spread the love of aluminum flygrrl Off Topic Forum 1 05-09-2015 12:02 AM
Pilot light lit, but flame doesn't spread. Steve Lohr Stoves, Ovens & Microwaves 6 06-02-2014 08:10 AM
Damage More Wide Spread, But Less Severe than Thought, Thiss Repairing/Replacing Floor &/or Frame 2 10-19-2013 03:42 PM
Gonna spread our wings.... pilgrim On The Road... 5 07-05-2008 05:50 PM
