Old 12-13-2020, 04:35 PM   #1
zen_stream's Avatar
1968 28' Ambassador
Portland , Oregon
68 corning hinge leak
Hey all,
Working on my ambassador 68 with the corning windows. I have issues with leaks coming from the top hinge. I have a few questions about the "fix" that was described in some of the forums.
Ive read that you can put some sealant in the hinge from the outside, move the window up and down for a while to work the sealant into the hinge and keep the hinge from binding from the sealant.
Has anybody out there tired this method and had success? How long should I do this "opening and closing" action? Also it was said that the sealant should be clear silicone but I've heard that silicone isn't good to use on airstreams. Why use silicone is this case? Also what brand/type of silicone seal should I use, I'm sure there are a lot of options?
Thanks!
zen_stream is offline   Reply With Quote
Old 12-20-2020, 10:08 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
While I can't answer the hinge question directly (I have heard something similar) I offer this.
Try looking at Vintage Trailer Gaskets to see all their drawings/diagrams in the library section for your year to make sure you have all the necessary gaskets and seals. Hehr also had some info.
And Vintage Trailer Supply sells the window eyebrows.
After working on our windows this weekend we feel your pain.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Glass replacement for Corning! Forrest Windows, Doors, Locks & Vents 104 11-26-2006 10:20 AM
Corning Glass for sale! driftwood Doors & Locks 1 04-23-2005 01:42 PM
Corning Glass window trim - Had any luck installing? Coloradobus Windows & Screens 0 07-17-2004 03:32 PM
