Old 04-05-2017, 06:49 AM   #1
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
25fb Rear Window Screen Pulled Out
I noticed last night a couple of inches of my bug screen on the lower frame as come out. I don't think I can repair this without taking the bug screen off.
Has anyone removed the bug screen off the rear window of a 25fb. It looks I will need to remove the curtains rails and probably the day/night shade.
Is the screen mesh the standard 18x16 mesh?
Kelvin
Old 04-05-2017, 06:59 AM   #2
Sag Harbor , New York
Looking from the inside of the trailer, the loose/missing screen spline should be visible in the screen frame screwed to the wall. I can see the spline on our FC20. If you carefully use a screen spline tool:
https://www.amazon.com/MR12010-Everh...en+spline+tool
. . . you might be able to work the loose spline back into its groove, although this is difficult with no extra screening protruding out past the spline. Yes this is standard Fiberglas screen material, either grey or black.
If you have to replace the screen, yes it will be much easier to remove the screen frame and do the work on a flat surface. You have to be careful, however, not to get the screen material too tight, as you can actually bend and change the shape of the frame. [The screen tool forces the spline into the groove, thereby pulling the screen tight.] Maybe get the top edge done, and the upper corners, then re-mount the frame in the opening, and "tack" the center of the bottom in place with the spline, and work your way toward the corners with the tool.
Getting the screen flat is an art, much like stretching an artist's canvas, where one works towards the corners from the center of each edge.
Hard to put into words . . .
Good luck!
Peter
PS -- There are cheaper double-ended tools available, with the other end meant to push the screen material into the groove, but the tool linked above is a better investment IMO, as it has ball bearings and a larger wheel. The lesser one will do the job.
Old 04-05-2017, 07:31 AM   #3
TRIPPPIN's Avatar
2012 25' FB Eddie Bauer
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I replaced all the screens in my 25fb in place. I used finer screen to keep out the no see ums. I don't recommend removing the screens - you can make the screen tight while installing in place and will have a better outcome IMO. I could not do the roof vents or the rear hatch screen but all the others were done without removing shades etc.
TRIPPPIN is offline   Reply With Quote
Screen window insert for rear/sink window? MaineStreamer 2005 - 2010 Safari 0 08-02-2015 12:09 PM
Window screen for rear window Safari 25 jackbickel Windows & Screens 0 07-24-2015 04:54 PM
'solar screen' replacement window screen jrsygrl Windows & Screens 3 06-23-2010 04:56 PM
Help I pulled the wires out of my 7pin conection to tow vehicle. AustinAir Towing, Tow Vehicles & Hitches 9 01-10-2009 06:24 PM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 12:13 PM
