Old 06-27-2021, 07:50 AM   #1
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
1/4 Turn Lock Screws
Does anyone know where I could get the 1/4 turn twist locking screws (not sure what the correct name is) that hold the the corner rock guards in place as shown in the attached photos? As you can see I have one that is missing.
Thanks!
ID:	398286   Click image for larger version
Old 06-27-2021, 07:52 AM   #2
Downhill502's Avatar
2020 27' Globetrotter
Fredericksburg , VA
Thanks!
https://odmrv.com/catalog/index.php?...si3j99orsspo82
Downhill502 is offline   Reply With Quote
Old 06-27-2021, 08:12 AM   #3
Kensington , Maryland
Hans,
Do a search here for several threads like this:
https://www.airforums.com/forums/f46...ml#post2373532
It may be worth your time to retrofit how the guards are secured. Briefly, the fix is to remove the bracket holding the rubber bumper and install an alternative fastener that is not made of Swiss Cheese
Above thread link includes all necessary hardware and good instructions.
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 06-27-2021, 08:21 AM   #4
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I purchased mine from Outofdoors Mart.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34' 1987 Limited 34'
1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 06-27-2021, 08:50 AM   #5
1986 31' Sovereign
Miami , Florida
They are called Dzus fasteners. Available from ODMRV and Aircraft Spruce.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
n2916s is online now   Reply With Quote
Old 06-27-2021, 08:54 AM   #6
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
Out of Doors Mart & Aircraft Spruce are good 'bookmarks' for AS owners, among others.
RivetED is offline   Reply With Quote
Old 06-27-2021, 09:27 AM   #7
turk123's Avatar
2019 30' Classic
Canfield , Ohio
I just called Airstream and they sent me some for free. That may not be possible today as they are so busy.
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 06-27-2021, 09:43 AM   #8
2006 19' Safari SE
Pittsburgh , Pennsylvania
Question Replace a screen
We got locked out of our 2006 Bambi (yes it happened when one of us exited the door and tripped the lock. Tape now covers the sliding lock to prevent reoccurrence). We had to cut through a screen on the side window to get into the trailor. How do we replace the screen?
Al Unione is offline   Reply With Quote
Old 06-27-2021, 10:42 AM   #9
2016 30' Classic
Houston , Texas
Got my spares at High Sky RV Parts https://highskyrvparts.com/new-airstream-parts. Also got a spare part that the screw goes into.
dhroberts is offline   Reply With Quote
Old 06-27-2021, 10:54 AM   #10
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
I got mine from southco.com
Streamracer is offline   Reply With Quote
Old 06-27-2021, 10:54 AM   #11
Norm
2010 23' Flying Cloud
2011 Avenue Coach
Lubbock , Texas
Try Airstream.
norm37 is offline   Reply With Quote
Old 06-27-2021, 11:57 AM   #12
1988 32' Excella
Robbinsville , New Jersey
You would be better creating a new thread. Since you cut the screen there are 3 choices.
1 The most expensive and probably the longest time, appointment at dealer
2 Find a local company that does screen repair (on houses, maybe boat awnings whatever these aren't special)
3 Buy some screen and a spline tool (available in most hardware and big box stores) remove spline, pry end out then gently pull, should be able to reuse spline (rubber string like piece holding screen in groove) and remove whatever is left of old screen, cut the new screen a couple inches bigger then needed, put over window, use spline tool to push spline and screen into groove around window trying to hold screen somewhat tight, then use a sharp utility knife to trim off access screen.
Edit; Don't pull on spline while pushing into groove or it will shrink back to original length and possibly pull out of groove,
Old 07-04-2021, 10:36 AM   #13
Rhode Islander
JandC's Avatar
Arcadia , Florida
On the fly screen repair so a rip or cut won't ruin your trip. Use a scrap of the fiberglass window screen from a residential window screen repair or get a small new pice from a store- 2x3 feet doesn't cost much. Cut the hole you have neatly with scissors so it's oval or rectangular with rounded corners. Cut a patch piece about a half inch bigger all the way around. Place the patch on the screen hold it flat, and hold your glue dispenser tip up against the overlap and put a medium thick bead all the way around in one shot. I use Shoe Goo from the Walmart shoelace rack but you could use clear caulking or whatever. It helps to have 4 hands for this and go out for the day while the fumes die down. Learning the part with the new screen and spline as described above is not to hard if you want to DIY when you get home.
JandC is offline   Reply With Quote
Old 07-08-2021, 08:25 PM   #14
Hans627's Avatar
I have got some of the Dzus fasteners but I cannot get them to engage on the top mounting points, the ones that are missing the Dzus fasteners. No matter how hard I push and twist and try to line them up correctly they will not engage and thus no secure attachment. I guess that is why the fell out in the first place.
So I'm going to try the route suggested by TooTall and make it a permanent fix. I'm not anxious to drill out the rivets but it seems pretty straight forward. Once completed I'll post an update.
Thanks for all the suggestions and ideas.
Storage lock replacements- southco lift and turn compression latches Troutboy Doors & Locks 20 06-26-2019 07:38 PM
Screws holding lock to door cecreighton Doors & Locks 4 10-17-2015 08:01 PM
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Replacing window protector cam lock screws wheel interested Rock Guards, Segment & Window Protectors 6 08-06-2010 10:09 PM
