Old 07-05-2022, 12:51 PM   #1
RichHog's Avatar
1972 23' Safari
Houston , Texas
Water pump failure on 2006 Safari 23íSE
The water pump started making some heavy vibrations making noises last light and wifeís desired shower just a drip. Finally located the pump under the driver side closet next to shower. No leaks and canít see a water filter/strainer anywhere to clean. When I turn it on I hear it run but water drips at sinks,shower. No outside water connections. Green light on water tank. Thoughts?
RichHog is offline   Reply With Quote
Shurflo Pump - check valve failure Robere Fresh Water Systems 0 04-02-2022 01:38 PM
Duramax LML CP4 fuel pump failure 80Ram Towing, Tow Vehicles & Hitches 13 04-07-2019 06:03 AM
Hooked up water in winter and can't get water pump to pump water mrpettit Water Heaters, Filters & Pumps 8 05-06-2015 06:46 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
