03-07-2021, 08:59 AM
2021 30' Flying Cloud
2020 25' International
minneapolis
Suicide doors
Curious...why do some models have suicide doors(left hinge)?
Is there a reason the doors open toward the ends of the trailer?
Structurally, I can’t see a difference.
03-07-2021, 09:02 AM
Oswego
Interference with windows and awning arms.
-Rich-
03-07-2021, 11:59 AM
Sag Harbor
, New York
03-07-2021, 07:16 PM
minneapolis
I’ll do everything to avoid the door flying open while traveling down the interstate. Anyone out there come up with a solution to eliminate the chance of the door opening and smashing the window if it’s open? I.e.: Cable to limit door travel, locking the window with something other than the standard latches.
03-07-2021, 08:35 PM
1966 22' Safari
Fredericksburg
I’m by no means familiar with newer Airstreams. But, a lot of vintage Airstream owners use a wooden “thingy”. It is a shaped wooden piece that is notched for the grab handle and sits in the handle and overlaps the door. Virtually impossible to fly open. Again, not familiar with newer models or where the exterior handle is located. Good luck
03-07-2021, 10:19 PM
2017 30' International
Broomfield
Use the deadbolt.
03-08-2021, 01:23 AM
Sag Harbor
, New York
See the search results in the previous post for various DIY preventers/wedges etc..
Originally Posted by OTRA15
Originally Posted by wulfraat
Use the deadbolt
Bingo!
KISS
03-08-2021, 05:01 AM
Kensington
, Maryland
Deadbolt of course.
Also, as a reminder I stuff a rubber doorstop under the grab handle.
03-08-2021, 06:18 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Dead bolt lock works for me. I fixed the door lock so it can not lock and use the added deadbolt lock exclusively. With 1" of deadbolt the door is not coming open.
03-08-2021, 06:25 AM
minneapolis
I “deadbolt” and “lock” the door when towing or leaving the AS etc. I’m concerned about someone opening the door, a gust of wind while opening...anything, ...and smashing the window if it were open.
03-08-2021, 06:29 AM
1989 29' Excella
1999 25' Safari
Youngsville
, North Carolina
s1000pre
I don't have a dead bolt on my 99 Safari, it blew open on me and caused the door to loose its curve. Was not able to fix. Got a door from a wrecked Safari. To keep it from happening again I drilled 2 - 1/4" holes in bottom edge of rain diverter over door, I put a bungee cord across door when traveling. Simple, inexpensive and effective. Be safe in your travels.
Steve
03-08-2021, 06:54 AM
minneapolis
If they had hinged the right side of the door, it would have barely obstructed the window in the bedroom. The door blocks out most of the window in the main cabin...silly!
03-08-2021, 06:58 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Use the deadbolt.
Yep...pretty simple, keep it lubricated, and don't travel without it engaged.
03-10-2021, 08:17 AM
1956 22' Caravanner
Don Pedro Island
Yes to above and a little reminder for me.
03-10-2021, 08:44 AM
2015 23' FB International
2007 19' International CCD
Steamboat Springs
The Fiamma swing lock is the best solution I have found. Secure and does not look like an afterthought, IMO.
03-10-2021, 08:58 AM
Steamboat Springs
Edit: its called the Safe Door. I purchased the first one from the Fiamma distributor in Florida, then the next two from ebay from an RV dealer in the UK.
03-10-2021, 09:47 AM
Sag Harbor
, New York
03-10-2021, 10:07 AM
Steamboat Springs
Actually, the correct model that works for our Airstream door frames is the Fiamma Safe Door Frame unit, though the plate does require trimming off about 1/2 inch.
Peter: as usual, thank you for your help in filling in the blanks!
03-10-2021, 04:09 PM
Sag Harbor
, New York
And thanks for the correction!
Echoing earlier posts . . . that a properly maintained and lubricated dead bolt is the KISS way to go here IMO.
