Old 01-31-2021, 09:27 AM   #1
2003 25' Safari
Paso Robles , California
Sticky Door Latch
The door latch on our Safari is very sticky/tight. You either need to use two hands when pulling the latch from the outside or press one hand above the latch when pulling with the other. Just as difficult from the inside as well.
We use the Airstream as an Airbnb and numerous guests have either thought the door was locked or just simply could not get it open.
Is there a solution????
PDNadeau is offline   Reply With Quote
Old 01-31-2021, 09:28 AM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
WD-40 or Silicone spray?
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 01-31-2021, 09:37 AM   #3
2003 25' Safari
I thought about trying WD40, but when I was checking to see if there were other threads with this same problem (none quite the same) people mentioned not using anything that would attract dirt/dust. Maybe a dry lubricant, if that exists?
'67 Overlander - Sticky Front Door Latch Billyjchase Windows, Doors, Locks & Vents 5 06-25-2020 01:55 PM
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
68GT - sticky door latch. Jinkers Doors & Locks 2 06-18-2012 07:26 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Sticky Door gmlcjb Doors & Locks 2 12-27-2003 06:42 PM
