Old 01-18-2005, 04:44 PM   #1
squeeky door
My airstream door just became hard to open. A very loud sgueak when opening it. When pushed open to the out side wall to the cetch.It wants to spring open about three inches.I have spraid it with lubrication , that did not help. Now I need to slam it to shut it . HELP
Rich is offline   Reply With Quote
Old 01-18-2005, 05:29 PM   #2
Rich.
Slicone spray, silicone spray and more silicone spray.
And in a few days, do it again and again.
Eventually, your door hinge will become quite again.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-19-2005, 10:53 AM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
how old is the coach? Have you checked the floor around the door opening for rot?
Our 1959 was dificult and the door had to be slammed ot latch. Floor was rotten and it cause some stress on the body on the hinge side. Once the floor ware replaced the door closes easily.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 01-22-2005, 04:54 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Cool
Andy is right; silicone spray is the best solution before you need to make repairs from forcing the door. That will only lead to more traumatic problems. It would be a good idea to check on the flooring as well to see if you have a structural shift?
Good luck!
balrgn is offline   Reply With Quote
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
Squeeky Hubcabs?!? coffeydelsol Wheels, Hubs & Bearings 7 03-02-2009 08:41 AM
Squeeky Wheel Gets the Oil! Dureedesign On The Road... 3 05-06-2008 08:05 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 04:40 PM
