Old 01-24-2020, 02:34 PM   #1
1999 34' Excella
Cinnaminson , New Jersey
Source for replacement compartment lock
ID:	359787Click image for larger version
ID:	359788Click image for larger version
Anyone know where to buy replacement locks? The screw threads are stripped out and the lever falls off. Can’t lock it or even close it anymore. I haven’t found a suitable replacement.
excellaf350 is offline   Reply With Quote
Old 01-24-2020, 03:31 PM   #2
runtime's Avatar
2004 28' International CCD
I’m been looking for the same lock. For a couple months with no luck.
runtime is offline   Reply With Quote
Old 01-24-2020, 04:14 PM   #3
cptdzl's Avatar
2018 27' Flying Cloud
Erie , Pennsylvania
Have you tried
https://shoprvlocks.com/
I changed my locks to the tubular cam locks and they have a great measuring sheet that might do the job for you.
EXPERIMENTAL based on untested ideas or techniques and not yet established or finalized
Rick & Becky #28279
2018 FC27FBQ
2021 RAM 2500 Hemi 6.4
KD3OBX 146.520
cptdzl is offline   Reply With Quote
Old 01-25-2020, 04:43 AM   #4
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Baggage Compartment Locks
These locks from Southco are no longer available. You can try setting the retaining screw in JB Weld. Make sure the cam is oriented correctly. If that doesn't work substitute a 1 1/8 cam lock barrel, reusing the original offset cam. You can't lock it, but it'll stay closed.
dieseleagle is offline   Reply With Quote
Old 01-25-2020, 05:52 AM   #5
FloydCoVa's Avatar
2015 23' Flying Cloud
Copper Hill , Virginia
I got mine from Out of Doors Mart, it was different lock but they had what I needed. Check there web site or just call them.
I just looked on there website and didn’t see yours but I would give them a call any ways maybe the can help or direct you. Good people to work with.
FloydCoVa is online now   Reply With Quote
Old 01-25-2020, 09:33 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Had the same issue - two choices 1) replace with a completely different lock system which would require a "patch" over the existing hole in the door or 2) replace the door with the latest lock used by AS (cost about $200) ...good luck
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-25-2020, 09:59 AM   #7
2019 25' Flying Cloud
West Windsor , Vermont
Or, try this one. If the threads are good on one side cover them with thin Vaseline. Thicken some epoxy and smear clean smooth side and insert. Allow to cure. The epoxy wont adhere to the greased areas so make sure surrounding surfaces are protected. When cured, carefully unscrew. You will have hopefully created new threads. Good luck
Peterf is offline   Reply With Quote
Old 01-25-2020, 10:26 AM   #8
2014 25' Flying Cloud
Temple , Texas
I bought my replacement locks from a locksmith.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
RamRider is offline   Reply With Quote
Old 01-25-2020, 04:46 PM   #9
1989 25' Excella
Hershey , Pennsylvania
Images: 13
You may be able to tap the screw hole to the next bigger size (ie. If the current screw is an 8-32, drill the hole larger and tap it 10-32) then you can install a new screw to hold the latch on.
89Excella is offline   Reply With Quote
Old 01-26-2020, 03:40 PM   #10
1999 34' Excella
Thank you!
I I dont want to replace the compartment or rework the entire lock just yet. I think I'll try the epoxy repair first. The screw grabs just a tad but pulls out pretty easily if you mess with it too much so I will try some 3M110 2 part epoxy from work. hopefully that holds I'll let you know out I make out
Storage Compartment Lock Replacement Ttaylor General Repair Forum 2 06-09-2019 11:00 AM
Storage compartment lock replacement jmichaelr Exterior Storage Compartments & Access Doors 3 11-16-2016 10:33 AM
Battery compartment lock. crazylev Batteries, Univolts, Converters & Inverters 7 02-29-2008 05:02 PM
source for exterior compartment door locks? stinky_hermi Doors & Locks 2 04-19-2007 05:23 PM
Fridge compartment lock Ladi Holovsky All Argosy Trailers 3 08-30-2003 11:37 AM
