05-31-2009, 08:40 AM
1972 23' Safari
Houston
Sliding Latch Door catch broken '72 Tradewind
The Latch is broken that holds the door open on my 72 Tradewind. It is a sliding black latch riveted to the skin. That part looks good but the other half on the door appears to be broken where the latch connects to hold the door open. Been using a bungie cord to strap it back so door doesn't flap in the wind but would love to fix latch the way it was designed. Any parts or work arounds?
Richard
05-31-2009, 09:49 AM
1958 26' Overlander
Mesa
Richard
Hi, Rich. Can you take a pic. It sounds like the base piece is intact but you're missing the top piece and spring. Is that correct? I just repaired all of my latches so I know what you're going through.
I bought my latch replacement parts from Oasis RV in Tucson. I also salvaged two complete latches that were part of a overhead storage tub. These parts are no longer made but you can still find them if you look hard enough.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
05-31-2009, 10:23 AM
Hey Richard,
I think it's the same part on our 76. I bought one and a couple of extras from Inland last year. The tip that catches under the body mounted slide bar broke on mine too. I keep the extras in a tool drawer along with my trusty pop-rivet tool.
William C. Swinney
05-31-2009, 11:40 AM
Corona
Richard
The new style "entrance door holdaback" consiste of a metal housing and a better black plastic latch.
Airstream has used that latch for about 35 years.
05-31-2009, 04:04 PM
1972 23' Safari
Houston
Door Latch
Here are two pics, one of the latch one of the catch. How to repair or replace?
09-24-2009, 06:11 PM
1973 31' Excella 500
Flagstaff
Richard, can't access your thumbnails. You have what sounds like a similar problem I'm having and I wanted a look at that latch. Any live link to the attached thumbnails? The one on the post above do not work.
JO in N Arizona
09-24-2009, 10:30 PM
1972 23' Safari
Houston
Latch
Will look for the pic and upload, I got a local RV repair shop to replace it.
It is the same latch that is used inside the closets and pantry in my Tradewind if that helps you.
09-25-2009, 02:06 AM
1993 34' Excella
Estancia
Your OEM latch is unavailable as new. The best replacement is the latch Andy speaks of above.
