Old 05-21-2024, 06:05 PM   #1
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Screen Door Rubbing
My screen door is rubbing after Airstream installed a lower screen door guard. Rubbing opposite screen door hinges on the lower side saddle corner. If possible anyone know how screen door is squared, trying to avoid a 130 mile round trip back to Airstream dealership. Thanks
Silvr_Bullet is offline   Reply With Quote
Old 05-22-2024, 04:28 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
I make no recommendation here, rather share an experience of mine. Several years ago we had a tech adjust an airstream screen door...it was actually hitting the main door latch post when closing.
He opened the screen door, separate from the main door, and pushed on it from the latch side, back toward the hinges, a couple shoves on the latch edge of the door back toward the hinge, at hinge height, really not a hard shove, which slightly bent/shoved the hinges a short amount back, and voila! closed the screen door and it cleared the post wonderfully!
Some times folks will hang on the screen door on the way in, or out, and the pressure will eventually "bend" those screen door hinges a bit, this is what the tech told me, and I think he was likely right in that assessment....not saying that's the case with your door though.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 05-22-2024, 11:03 AM   #3
2017 16' Sport
N/A , N/A
After reading your post I tucked an 1/8 ď plastic paint edging tool under the corner that was rubbing and that was enough to make the correction, works fine now. 😊 Thanks!
Old 05-23-2024, 04:53 AM   #4
Totally Awesome! It's amazing how easily those screen door hinges can get bent out of alignment....and how easy it is to put 'em back where they belong
New 2023 I19 4x4 Door Rubbing on paint cactusjk Sprinter and B-van Forum 6 07-23-2023 07:51 AM
Window arm rubbing on bug screen steilkurve Windows & Screens 5 08-01-2022 11:36 AM
22' bathroom door edge rubbing Simbone47 2005 and newer - Bambi all models 2 12-13-2019 08:03 AM
Axle bent rubbing on undercarriage Modern South Axles 9 03-29-2013 09:38 PM
2009 Panamerica awning rubbing on door Pedecanada Awnings 23 02-19-2013 11:28 AM
