Old 07-31-2017, 05:12 PM   #1
wareaglewalt's Avatar
2017 25' Flying Cloud
Bushnell , Florida
Screen door plastic slide security
We have a cat that's traveling with us and has figured out how to slide the plastic cover on the screen door over to escape. Fortunately she hasn't ventured far nor taught the other 2 cats how she did it (yet). Question is has anyone found or devised a spring type solution (or anything else) to keep that plastic slide in place where it would take some force to open it to get to the door latch?
And I've read that plastic slide is called a "gizzy". Is that true?
Joe
wareaglewalt is offline   Reply With Quote
Old 07-31-2017, 10:02 PM   #2
WaLee's Avatar
Nevada City , California
Put a rivet with a short spacer at the closed end of the slide track in the frame. Put another in the sliding door with a spacer at about center. Stretch a rubber band around them and it will automatically close the slide. I can take a picture in the daylight tomorrow. Learned this trick at a rallly.
WaLee is offline   Reply With Quote
Old 08-01-2017, 08:09 AM   #3
WaLee's Avatar
Here are some picsClick image for larger version
ID:	291020Click image for larger version
ID:	291021Click image for larger version
Old 08-01-2017, 08:12 AM   #4
WaLee's Avatar
I made the spacer out of brass tubing but you could get a plastic one from the hardware store out of the small parts boxes by the specialty nuts and bolts. I put a small washer on slide one then set the pop rivet
Old 08-01-2017, 10:28 AM   #5
2007 22' International CCD
Slick idea. Making a copy....(stealing it gratefully). Kudos to the person at the rally!
Old 08-01-2017, 10:54 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I think the "gizzy" is the little caterpillar looking part on the door frame to cover where the door frame is notched out to go around the striker bolt thingy.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-01-2017, 12:24 PM   #7
1997 25' Safari
citra , Florida
We have two cats i put one rivet centerd in the metal be for the hatch . It works for us
bill messer is offline   Reply With Quote
Old 08-01-2017, 01:00 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Standing inside, see the bottom groove (track) where the plastic door slides? Get a piece of 'all thread' which will lay in the groove, not fall out or fall into the track. Place inside and gently close the door so it doesn't fall out.. think of it as the kind of "screen door lock" where you drop in a wood stick to stop door from sliding..
if you don't have a blind rivet tool, a screw for the rubber band would do the trick...
Peace and Blessings..
Channing
WBCCI# 30676
Slide cover for the screen door replacement mopariac General Interior Topics 17 08-25-2020 03:55 AM
Need Plastic Cover for Screen Door 1973 31' charles12 Doors & Locks 24 05-24-2015 03:05 AM
Screen door sliding plastic panel, bug guard angellhill Doors & Locks 5 07-18-2012 08:48 PM
Screen door slide Hardenburgh General Repair Forum 1 05-27-2012 12:41 PM
screen door slide Alice Cabinets, Counter Tops & Furnishings 3 07-10-2002 07:56 AM
