Old 01-17-2021, 10:49 AM   #1
1977 31' Sovereign
Dorr , Michigan
screen door frame issue
Today I decided to start taking the skins off the door of my 77 sovereign and i noticed at the point of the lower hinge attachment the frame is split between pop rivets and the buck rivets. anyone have this issue and what did you do to correct/fix it?
crazycuda is offline   Reply With Quote
Old 01-17-2021, 11:05 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had that happen when I had a 75. It was caused because the screen door hinge bottomed against the door frame before the door was completely closed. To close the door fully, the door had to flex at the rivets and the metal split.
I removed the door and had a shop weld it back together and I adjusted (bent) the hinge to let the door fully close. On my trailer I had 6 rivets (3 buck and 3 blind) holding each hinge to the door.
Richard
azflycaster is online now   Reply With Quote
Hi guys got a frame issue. Frame channel looks half gone in front under sofa by the d MyNancy1977 Repairing/Replacing Floor &/or Frame 3 07-19-2017 01:42 PM
How do you remove a screen frame to replace screen? Astrodokk Classic Motorhomes 5 05-29-2016 06:33 PM
Beatrice era frame experts if you please. Odd frame issue Kevin245 Repairing/Replacing Floor &/or Frame 5 08-25-2012 09:55 AM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
