01-23-2023, 10:43 AM
1999 28' Excella
New Orleans
, Louisiana
Rain getting in!
Our back storage compartment is getting wet after a rain. I tore out the carpet and pad it was so soaked. After another rain more wet wood. The only thing I know to do is replace the gasket. Anyone else have this problem?
Kat
01-23-2023, 02:59 PM
2018 30' Classic
Thousand Oaks
Damp rid and an air mover will help pull the moisture out. Our rear hatch we can adjust the latches so it closes tighter. Any luck with that? Otherwise you’re right, best best is replace the gasket and adjust the door as needed.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
01-23-2023, 05:18 PM
1999 28' Excella
New Orleans
, Louisiana
Thanks for the suggestion of adjusting a tighter fit. Our door actually has a thin d channel gasket that Out of Doors Mart says that appears to be a previous owner add on. I will replace the gasket where the door closes into.
01-23-2023, 05:35 PM
Brooks
, Georgia
Is it possible that the water is coming in from where the bumper attaches to the camper? I used 3m strip calk on mine but it lives inside when not in use. It hasn’t been outside much in the rain since I did it.
01-23-2023, 05:53 PM
2020 25' Globetrotter
Hillsdale
, New York
Do you know if the water gets in while towing, or when parked?
SPP
01-23-2023, 07:58 PM
2017 16' Sport
N/A
, N/A
You could try placing bright lights from the inside, at night if you see any escaping light around the gasket that may confirm your suspicion.
01-23-2023, 09:03 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I tore the carpet out, drilled drain holes in the drawer, installed drain tiles and resealed the belt molding. I did the same to all storage compartments.
17yrs SFSG.
“Listen, or your tongue will make you deaf” Native American proverb.
01-23-2023, 10:14 PM
2017 25' International
West Lake Hills
17yrs SFSG.
^Nice solution.
I don't like mold; therefore, I don't like carpet.
I've removed carpet from eight houses I've owned. Each one had mold in at least one area. Bathrooms are the worst. Carpet is a sponge, holding water, wetting the substrate for extended periods of time. Replaced it with hardwood, vinyl, or porcelain/ceramic tile.
I'm very happy that my AS has no carpet anywhere.
01-23-2023, 10:51 PM
1995 25' Excella
xxxxx
, xxxxxx
Confirm the gasket is the problem first. After you dry the compartment, go to the hardware store and get some masking film with blue painters tape already attached. Put a piece of the plastic film over the compartment and tape it down. See if the compartment gets wet after the next rain.
I was getting a little water in my side compartments. I traced the problem down to the rivets that hold the hinges on. The hinges are outside the gasket. They get wet. The rivets are ordinary pop rivets. I believe the heads leak. I put some sealant on the rivet heads and around the edges of the hinges. My compartments are dry now.
01-24-2023, 12:16 AM
Salem
, Oregon
 Hi, The factory storage door seal does practically nothing. Mine didn't leak water, but leaked cold outside air under our bed. I used double D weather strips all around the storage door. [note, only one shown in these pictures] No more leaks.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
01-24-2023, 08:38 AM
2008 27' International FB
Petaluma
Hi Bob, do you have a MFG / Part number for those weather strips?
____________________
- Brad
01-24-2023, 09:17 AM
1994 30' Excella
Mississauga
, Ontario
In my ‘94 I had a leak at the licence plate bracket. It is a large plastic moulded piece that is installed in a cutout in the outer skin. I caulked around it with Acryseal 15 years ago and so far still no further leak.
Al and Jean
TAC ON-3
01-24-2023, 11:04 AM
1994 30' Excella
alexandria
, Kentucky
How is the caulking around the bottom rub rail, above windows, behind the clearance lights, around the awning brackets, between the bumper cover and body, etc....
My trailer leaked like a sieve until I took some time to dig out the old caulking and recaulk a few things.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
01-24-2023, 12:49 PM
West Lake Hills
The factory (I'm assuming) weather-stripping around the compartment door on my trailer was installed with the ends (and potential gap) at the bottom. After frequently knocking it loose at the bottom, I flipped it around so that the ends are at the top. No more knocking it off. And I discovered that the weather-stripping was cut about a half-inch short.
I'm interested the part number of the Double-D weather-stripping, too.
01-24-2023, 03:59 PM
Salem
, Oregon
Frost King.
 Hi, most any hardware store will have this weather stripping. I was unable to find a part number or even a picture of this in a package.
