Old 01-29-2023, 01:00 PM   #21
gator.bigfoot's Avatar
KW , Ontario
Originally Posted by badkat View Post
Our back storage compartment is getting wet after a rain. I tore out the carpet and pad it was so soaked. After another rain more wet wood. The only thing I know to do is replace the gasket. Anyone else have this problem?
Kat
I had the same problem. It was a pin hole leak in the caulking around the outside bezel. I removed the old caulk and re-caulked and it's been dry since. I removed all the carpet inside and replaced with a gym mat that interlocks. Works well no issues since.
gator.bigfoot is offline   Reply With Quote
Old 01-29-2023, 04:38 PM   #22
1998 25' Safari
Golden , Colorado
Airstream leaks are deceiving! I had the same problem and thought it was the door seal also. After a lot of testing and searching, removing and resealing the rear window, removing and resealing the clearance lights - I found the rain/water was coming through rivets and seams above the window and running down the inside skin. Had to replace part of the floor because of the leak. The leak only stopped after sealing all the seams and rivets in the roof. Looks like crap but doesn't leak!
Ravenquest is offline   Reply With Quote
Old 02-07-2023, 09:39 PM   #23
1999 28' Excella
New Orleans , Louisiana
My compartment was soaked. i am replacing the gaskets and the outside caulk
if I can figure out what kind of caulk.
badkat is offline   Reply With Quote
Old 02-07-2023, 11:06 PM   #24
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Here you go. Good luck.
https://amzn.to/3jE1RgV
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-08-2023, 05:33 AM   #25
"Cloudsplitter"
Here I go .....went.
POI...used 'went' on the roof vents, antenna's, skylight, black tank vent 7yrs ago. SFSG
Old 02-09-2023, 11:59 AM   #26
1999 28' Excella
Sorry I have been off line for a bit. We had a down pour of rain last night. I believe I know where it is coming from....yes THE BUMPER! Need to find some black caulk for my rubber bumper. Also maybe some silver around the edge of the aluminum!
Old 02-09-2023, 12:00 PM   #27
1999 28' Excella
Seems to be when sitting still!
Old 02-09-2023, 12:04 PM   #28
1999 28' Excella
The spot that gets the water the most is where water puddles on the bumper. No walls or ceiling dampness. After the rain last night a puddle was in the compartment close where the bumper was still damp. Do they make a rubber black caulk?
Old 02-09-2023, 05:50 PM   #29
2018 30' Classic
Same stuff, different color. Never used the black though, only the silver used here.
https://amzn.to/3xdJvGw
BigSxyWhtGuy
Old 02-11-2023, 02:57 PM   #30
"Cloudsplitter"
What we did here...before I found the 3M stuff.
POI...it's not so much what you use it's that you use it. This was 11yrs ago.
ID:	428010   Click image for larger version
Airstream vs Rain Gutter (rain gutter won) mkarahashi General Repair Forum 16 02-28-2022 06:40 PM
Getting ready to travel back to the dealership to pick up our 2019Nest 16U. Getting m RichAnthony Nest 2018 - Current 2 10-06-2020 02:32 PM
Rain, Rain, Rain knunut Off Topic Forum 12 01-10-2013 07:25 PM
Rain V. Walbernize - Rain Wins monkeypants Our Community 0 08-22-2009 08:18 AM
Rain, rain, go away... Twinkie Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2007 04:50 PM
