Old 05-24-2022, 07:24 AM   #1
hikingcamera's Avatar
2022 23' Flying Cloud
Seattle , Washington
Quiet entry and exit?
So Iíve seen and read that the Airstream door is really hard to get fully closed without slamming it. We are going to be camping with kiddos. Iím curious if other families have experience or strategies for entering and exiting your trailer quietly (without waking the kiddos or your neighbors)?
hikingcamera is online now   Reply With Quote
Old 05-24-2022, 07:32 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
Closing from the outside, you can push the door rather softly til it first stage latches, then push hard in the area of the latch to fully close.
From the inside, no way that I know of but to slam it We never pull it closed using the door handle, ALWAYS pull closed using the screen door handle.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is online now   Reply With Quote
Old 05-24-2022, 07:35 AM   #3
SlowPokePete's Avatar
2020 25' Globetrotter
Hillsdale , New York
Is there a reason for doing it this way?
I ask because I know I have been told to always close the two doors as a unit, not with the screen door already closed, to avoid "problems."
These Airstream tips to avoid breaking something are rather important to me
SPP
SlowPokePete is offline   Reply With Quote
Old 05-24-2022, 08:14 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
SPP
Hey slow poke Pete, check this thread out about why not to use the door handle to pull close unless modified. I modified mine plus added a second handle for closing.
https://www.airforums.com/forums/f45...ml#post1786439
For the OP: Like MajorAirHead, I close the door gently to the first latch and then push (or pull on separate handle) hard to close second latch. Also, when taking the dog out early for a walk, I leave the door ajar (if it's not windy) when I go in and out to alleviate the closing noises. - Brad
SuperTrouper is offline   Reply With Quote
Old 05-24-2022, 09:30 AM   #5
Lily&Me's Avatar
Normal , Illinois
Unless you’re going to be away from your trailer, just don’t close the door completely.
That’s what we always did traveling with the grandkids.
Maggie
Old 05-24-2022, 09:32 AM   #6
Originally Posted by Lily&Me View Post
Unless youíre going to be away from your trailer, just donít close the door completely.
You donít get drafts and lose a lot of heat through the cracks in the door that way?
Old 05-24-2022, 10:25 AM   #7
Lily&Me's Avatar
Normal , Illinois
A little, but that is offset by not waking small children nor neighbors who are not early risers.
Maggie
Old 05-24-2022, 10:42 AM   #8
stevejones's Avatar
2019 27' Globetrotter
Litchfield Park , Arizona
If the door is properly set up and adjusted you should not have to slam it. It took several adjustments at the Factory Service Center to finally get it right. We do not have to slam ours. Will the set up last? Probably not. Like everything else the door is subject to bounces, jars, vibrations, and stress from being opened and closed.
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
stevejones is offline   Reply With Quote
Old 05-24-2022, 10:56 AM   #9
1997 25' Safari
Laurel , Maryland
Thank you
You should not need to slam your door!
ďVinneyís RV ? In California has a good video on YouTube on how he adjusts airstream doorsÖ. To put it like he says, you should not need to slam the door if it is properly adjusted.
My 1997 Safari, closes quietly with the 2 clicks as he shows you how to do. (Shhhhh says Rick)
Rick n Mary is offline   Reply With Quote
Old 05-24-2022, 11:12 AM   #10
2015 25' Flying Cloud
Schaumburg , Illinois
Ours is also a bit difficult to fully close but I hate the notion of slamming the door. Through trial and error, we have come to the point where it is pretty easy to accomplish quietly. Just softly close the door right to to the point of contact, then from the outside, with an open palm just push firmly against the door, right at the level of the door latch, to get it fully closed (no slamming), and if you really want to reduce noise you can hold open the door latch while closing, then release the latch once the door is in the fully closed position. From the inside of the trailer, closing is a similar process, but we always pull it closed on the main door handle, not the screen door handle. It is slightly noisier from the inside, but still can be accomplished without a "slam". Too much force needed (for our door) for an inside close to use the screen frame/handle. We have also realized over time that a poor job of 4-corner leveling of the trailer results in slightly out of square in the door jamb, and can significantly complicate the door closing process. Be sure you carefully level your trailer with an equal balance of pressure from the 4 stabilizer jacks. Just enough jack pressure to take the "bounce" out of the trailer when walking through on the inside. I don't think it matters for this topic, but our trailer is an RB (forward door) floor plan.
1StreamDream is offline   Reply With Quote
Old 05-24-2022, 11:34 AM   #11
Oh good! Iím so glad I asked this before we pickup our trailer. I will make sure that it is properly adjusted before we leave and will be sure to learn how to keep it adjusted. I have to be honest, itís pretty unbelievable that the expectation on a $100k trailer would be you just have to not close the door in order to not wake the entire campground.
Old 05-24-2022, 07:33 PM   #12
Life is a Highway's Avatar
2018 25' Flying Cloud
2019 25' Flying Cloud
2021 30' Flying Cloud
Lady Lake , Florida
Yep
We had to be persistent but the factory got it PERFECT! Then 1000 miles later the inside door hinge nuts broke free and cannot be re-tightened. Sooo its back to Jackson Center for a July appointment to start the process all over again. Our door closed with a palm push from the outside. Like Others i reinforced the door handle but we close from the inside pulling on the screen door handle.
Life is a Highway is offline   Reply With Quote
Old 05-24-2022, 08:31 PM   #13
Hopefully my local dealer or I can figure it out, because a visit to Jackson Center is not realistic for me anytime soon. Lol!
Old 05-24-2022, 09:46 PM   #14
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
Yea, I was mortified, after three years of camping all over the US, a campground manager came to me saying the neighbors were complaining about my door slamming. After making the door lock mod, I gently pull it closed.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 05-24-2022, 10:10 PM   #15
Here's the scary video about how to adjust the doors. Good info but don't expect engineers with calipers in lab coats! https://youtu.be/j7-PprGeESE
Old 05-25-2022, 07:20 AM   #16
SPP
Screen door latched to main door, then pull closed using screen door handle or grabbing anything OTHER THAN the main door handle.
Old 05-25-2022, 10:34 AM   #17
Oh great. My takeaway from that is if I breathe on it wrong, it may get out of alignment, and if it's bad enough I may need to start drilling rivets to fix it. And I have a toddler and an infant right now. I'm hosed.
Seriously though, I need an offline set of instructions for that lol. Can you imagine finding you have to make that adjustment with poor or no cell service to re-watch that video? LOL!
Quiet and Non-Smelly Portable Electric Heater Recommendation interstateflyer Winter Living 22 11-06-2019 04:51 PM
Quiet and Reliable Non-Ducted Air Conditioner? Secguru Interior Restoration Forum 4 09-11-2014 03:21 PM
"Exit Now" or "Next Exit" which is better hhendrix On The Road... 2 05-23-2010 03:07 PM
Exhaust pipes to exit left but where? Astrodokk Airstream Motorhome Forums 6 10-18-2003 08:21 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
