Old 11-27-2018, 10:07 PM   #1
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Orphaned Tradewind door
I got involved with replacing the screen in the door of a 1951 Tradewind. It looks like it may have had some creative/innovative mods though. What looks particularly strange to me is the method used to secure the 'center' solid panel that covers the screened area in the door when the trailer is closed up.
This door as currently configured has two slots in the screen to allow two blades attached to the inner panel to go through the screen and be secured with an upper and lower transom catch on the leading frame when the panel is closed. Can this be original?? The original lockset is missing but I wonder if that was the original method?
Can anyone tell me how the original system was set up?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 11-27-2018, 10:45 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
These might work: https://www.vintagetrailersupply.com...-p/vts-399.htm
I will try and take a picture of the screen door on my 1954 Liner this weekend.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 11-28-2018, 07:14 AM   #3
1966 22' Safari
Fredericksburg , Texas
Did you mean 1961 Tradewind? AS started making Tradewinds in the latter 50s. Regardless, the door within a door had two tabs on the door within a door that fit through the screen edge and outer door. That is original. It was held closed by two sliding bar latches. What Wkerfoot indicated will work. I think they still make some latches that look original. They weren’t solely used in Airstreams, but screen doors in houses and other doors that required latches. This method of keeping the inner door secured while traveling makes me nervous. Good luck
Bubba L is offline   Reply With Quote
Old 12-03-2018, 02:50 PM   #4
Excella CM's Avatar
Venice , California
Thanks for the info. While I was replacing the screen in the door, the trailer melted in the Woolsey fire! Now I have an outer door that doesn't fit anything I have.
Pre-war Door Hinge (Door-in-door) ekstarr Doors & Locks 0 06-26-2018 02:37 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
will a '67 Tradewind door fit a '62 Tradewind? scoxx30 Doors & Locks 4 11-21-2005 11:58 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
