Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-05-2013, 11:40 AM   #1
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
Olympia , Washington
One way to repair an entrance latch (KT Lock)
Last week I couldn’t open the entrance door to our 1978 Argosy. The latch handle pulled open, but the slide bolt didn’t move. When my husband removed the KT lock, he found that the tip of the lever that depresses the slide bolt spring had broken off. He removed the origninal thick rusty washer and put new thinner ss washers of the same diameter on either side of the shaft pin. Now the broken lever pushes on a washer rather than a pin. The cost was only a few cents and it works better than ever.
Another note: While you have the lock apart you may want to take the lever+shaft to a shop to have it spot-welded. The original job looked shabby.
How it looks now (with lithium grease):
LTD30 is offline   Reply With Quote
Old 06-22-2013, 06:25 AM   #2
247stream's Avatar
1986 25' Sovereign
Marietta , Georgia
thanks for sharing...
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 06-22-2013, 07:20 AM   #3
mandolindave's Avatar
It sounds like like a great design
Is it too late for more pictures? Maybe a diagram or a drawing?
mandolindave is offline   Reply With Quote
Old 07-03-2013, 04:35 PM   #4
LTD30's Avatar
1999 30' Limited
1978 24' Argosy 24
Sorry, but it's been installed. Will try to answer any question that you might have.
