Old 04-09-2020, 11:02 AM   #1
2015 27' FB Eddie Bauer
Braselton , Georgia
Mystery hinge issue
Iíve read almost all the threads on here about loose door hinges. Iím trying to get As much input as possible before tackling mine. My situation is a little different from what Iíve read. and I may being too gentle. The lower screw on our upper hinge appears to be loose; when we open the door it pulls away from the frame a couple millimeters. I thought it would need simple tightening but when I pulled the drill/screwdriver out the bolt was already really tight. I didnít go at it too hard (a 9 out of 15 on my Dewalt) because I was nervous to break it off. The hinge appears to lay flat when door is closed. And when opening the bolt remains in the same place within the hinge, pulling out and going back in with the hinge. Has anyone seen or heard of this? Iíd assume the nut had come off inside if the bolt was spinning freely. Any thoughts? Other things to check?
bikepacker83 is offline   Reply With Quote
1968, Door Hinge issue jenny68 Vintage Kin 0 01-01-2020 08:40 AM
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
