Old 08-01-2020, 12:08 PM   #1
2019 30' Classic
Pleasant Garden , North Carolina
It happened to us!
Well, after a year and a half of ownership we finally got locked in our 2019 30' Classic. Got up this morning and couldn't get out to take the dog to relieve herself. Nothing we could do to open it from the inside. Got our neighbor camped next to us to try and open it from the outside, that didn't work either. Finally I climbed out through the emergency window (no small feat being 66 and 20 lbs overweight) to freedom. I tried to open it to no avail for about 10 minutes. Miraculously,it decide to open. We decide to continue our weekend by just pulling the door slightly closed and hopefully getting it fixed when we get back home. Kind of embarrassing camping in a new Airstream and having to ask someone in a pop up to try and get you out.
jlandreth is offline   Reply With Quote
Old 08-01-2020, 12:13 PM   #2
PB_NB's Avatar
2019 22' Sport
Port Coquitlam , British Columbia
There is a thread that talks about how to fix the handle and how to access the latch from the inside as well.
Glad to hear that you were able to escape! I can't imagine climbing out the emergency exit window! Did you get that on video
Peter.
"Live Long and Prosper \\//" - Spock
PB_NB is online now   Reply With Quote
Old 08-01-2020, 12:29 PM   #3
Sag Harbor , New York
"locked inside" -- https://www.google.com/search?q=lock...=airforums.com
The user RFP posted details in one of the 23' threads as I recall. I will look later.
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 08-01-2020, 12:32 PM   #4
2019 30' Classic
I'm sure someone did! We keep expecting it to show up on Facebook.
Old 08-01-2020, 12:34 PM   #5
2019 30' Classic
more coming on erdit plrease stand by
The fix threads are all great but the fix requires you to be able to work on the door when it's open. Unfortunately there's nothing on how to get out once it happens to you.
Old 08-01-2020, 12:35 PM   #6
You went out the only way available without destroying the door/lockset IMO.
Over and out.
Old 08-01-2020, 12:39 PM   #7
PB_NB's Avatar
2019 22' Sport
The fix is probably more of a between trip fix as it will require some tools. Create a small notch into the screen door to expose the latch and then a small screw driver to flick it open. This one can be done if you can find a way to trim the screen door frame a tiny bit. A file or some snips might do it.
https://www.airforums.com/forums/f45...od-150277.html
Peter.
Old 08-01-2020, 12:59 PM   #8
2019 30' Classic
Over and out.
I think you are right. I'm not sure why it opened when I went outside and not when my neighbor tried it. Maybe he liked the idea of keeping the guy in the shiny Airstream locked inside to see what he would do.
Old 08-01-2020, 01:14 PM   #9
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
After reading the earlier threads about the failure of the latch and getting locked in the trailer I went out and took a good look at the door latch mechanism.
I imagine that cutting a notch in the screen door would probably make the procedure a bit easier but I am able to use a thin screwdriver with a 4" shaft to trip the release tab for the latch without having made any modifications to the screen door. I practiced doing it several times so it wasn't a fluke.
I suppose it's possible that the latch on a FB Globetrotter like mine is configured differently than one on a rear bedroom trailer (upside down maybe?) which could somehow make the process more difficult. In any event, that screwdriver now has a special place in my trailer.
Mike
“The thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2020 25' Globetrotter Twin
2017 F250 4x4 6.7 max tow Platinum
400Ah Battle Born lithium battery string
580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 08-01-2020, 01:23 PM   #10
PB_NB's Avatar
2019 22' Sport
Hi Mike, I think on the newer trailers, there might a notch trimmed back on the screen door frame as this was a known issue. Sort of an undocumented escape procedure. I think this was discussed in one of the 23 threads on this topic. Now if Airstream included a little handle to pop the latch, that would make complete sense.
I did the door handle fix already but haven't checked the notch on my door. I will do that this weekend while I work on my power systems.
Peter.
Old 08-01-2020, 01:51 PM   #11
mikeinca's Avatar
Hi Peter, the photos below show my 2020 GT screen door frame. I don't see a notch but maybe the entire frame is thinner than on older models. Does it look different to anyone? You can also clearly see the the release tab which is easily accessible with a thin screwdriver.
ID:	374584   Click image for larger version
Mike
Old 08-01-2020, 02:14 PM   #12
PB_NB's Avatar
2019 22' Sport
I had a look at mine and it appears that the frame is in the way of the little tab. I would need to trim the frame down a bit so I could reach it with a screw driver.
ID:	374587   Click image for larger version
Peter.
Old 08-01-2020, 02:18 PM   #13
PB_NB's Avatar
2019 22' Sport
I might be able to get to the latch like you show if I had an angled point on the end of the tool
Peter.
Old 08-01-2020, 09:27 PM   #14
gator.bigfoot's Avatar
KW , Ontario
I just pulled the spline in the window screen opened the window and reached out and opened the door. Takes all of 10 seconds and another 30 seconds to reinstall the spline.
gator.bigfoot is offline   Reply With Quote
Old 08-02-2020, 03:51 AM   #15
Just to close one circle on the research for this mod --
The thread linked in the following post is RFP's fix, in that case for the door handle falling off:
Thanks Peter for that link. I did not have time yesterday to check it out.
Here is RFP's OP in that thread -- click on the orange arrow in the quote to go directly there and see the attached photos:
Originally Posted by RFP View Post
OK, I'm a worrier. When I saw this thread about the entrance/exit door handle breaking off, it got my attention: https://www.airforums.com/forums/f44...ht-133974.html
Having no interest at all in crawling out the "emergency exit" of our 23D, I started checking the latch mechanism to see if there is a way to get it open even with a totally-broken-off-handle.
As it turns out, there is.
In the attached photos, you will see a little "tab" inside the door latch mechanism. Lifting "UP" on this tab will release the latch... exactly what happens when you turn the handle.
Attachment 261903
So, a few minutes work with a file to create a "notch" in my screen door frame, and drilling a small hole in the door frame allows me to "trip" the latch with a small Phillips screwdriver (now residing in my inside-the-trailer tool kit).
Attachment 261910
I bought some fuzzy-side Velcro and made new pads for the door frame. I cut a "X" where the hole is drilled in the frame, and, sure 'nuff, the screwdriver goes right through and with about 5-seconds of hunting for exactly the right place, "POP" my door is open.
Attachment 261904
Attachment 261905
I plan on buying a new handle assembly (they are only just over twenty bucks) and carry it as a "spare." This level of preparedness should ensure my handle never breaks!
"Spare" door handle here: http://airstreamsupply.com/New-Airst...e-lh-381547-02
Rob
Thanks Rob!
FWIW another thread to check out:
https://www.airforums.com/forums/f45...le-184660.html
Video from one of the "locked inside" threads: https://www.flickr.com/photos/nixfrixshun/41823973780/
Will check out our 2014 FC20 lock today. Apparently this model year may be one of the [sufficient but not necessary] red flags.
Thanks for everyone's input.
Happy trails,
Old 08-02-2020, 04:09 AM   #16
Works only in certain models IMO.
Old 08-02-2020, 09:37 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One of the things to consider, especially since this is a new trailer, is to check your adjustments of the stabilizer jacks. I've noticed over the years with my Classic is that when i lower a jack (and I have the electric jacks) I stop the lowering process when I hear the jack motor change pitch and you will notice a slight rise to the trailer in the area of the jack. At that point i so a quick,slight reverse of the direction and take a little pressure off that jack. I follow the same process with each jack as I extend it.
The fact is you can torque the frame and with that small amount of over torquing, it usually shows up as a harder to close door or a situation that while the handles operate inside and out, the door fails to open. Those of us with the slide outs are particularly susceptible of torquing due to the weight of the slide out. Hence, the fact that you do not extend or retract the slide out without the stabilizer jacks being down. While I'm not discounting the possibility of a defective door latch, understand that similar symptoms can occur if you have a stabilizer jack that is putting a little too much pressure on an area of the frame. In my early days with my trailer I did notice some tendencies of the door not opening due to my applying too much lift on a jack. Once backing off the torque I found the door latch easily operating.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 08-02-2020, 11:20 AM   #18
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
I've made the mod to the screen door and frame, only needed a notch rather than a hole, and painted the tab with white nail polish, easier to see with these mature eyes! An old screwdriver sits in the cabinet next to the door.
jcanavera has a good piece of info. It's very easy to torque the frame with the stabilizers or just some uneven ground. It doesn't take much too much.
Sometimes pressing in a little on the outside of the door near the lock will relieve the pressure on the lock allowing the jaws to release a lot easier.
RivetED is offline   Reply With Quote
Old 08-04-2020, 11:44 AM   #19
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
Ron showed us this fix the lock and I did mine. Quite easy to do. Not sure if it works on all years, but his AS was newer than mine (mine a 2013) and it worked for me.
https://www.airforums.com/forums/blo...+lock&u=105870
WW
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
Old 08-09-2020, 10:40 AM   #20
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Don’t travel with it partly closed
What happened to the "Woody"? Penguin Our Community 2 08-24-2003 11:58 AM
what happened to HEX qqq Off Topic Forum 7 07-01-2003 09:13 PM
What happened to the Solar/Maxx ? femuse Roof Vents, Skylights & Fans 1 03-30-2003 09:41 AM
What ever happened....??? gwsullivan Our Community 2 02-13-2003 04:11 PM
moved and tore loose what happened overlander General Interior Topics 5 09-24-2002 06:50 PM
