Originally Posted by soldiermedic
Here is a picture. Something like this for the outside, but to fit my 68 Safari.
Airstream used a "T" handle lock for the entrance door in 1969 as well as all the compartment doors. They were made by Chessler. The big problem was all to many things got caught by the extended handle that more often than not hurt you or caused damage to the trailer.
The manufacturer of that lock went out of business.
Airstream then decided to use a "flat" lock such as the KT from 1970 to 1977. After 1977, Airstream has used several different locks, but all with a flat exterior surface.
The
1966 to 1969 locks, all had a handle on the inside. In time, as you closed the door from the inside, that handle would easily break. In fact probably 75 percent of that vintage lock was replaced because of the inside handle breaking.
Using a round knob on the inside, solved that problem.
At this point in time, a Bargman L-100 special is used as a direct replacement for the
1966 to 1969 models.
We developed a kit for the 1970 to 1972 models, which replaces the $600.00 KT lock, using the Bargman L-100 special plus some adapter plates. The cost is now less than $160.00. However, it does have a round knob on both the inside and outside, and still keeps your tariler in the Airstream family of parts.
We also developed a lock kit for the 1973 to 1977 trailers that also greatly reduced the costs, and is flat.
Locks for the 1978 to 1991 also became expensive or obsolete, therefore we developed a replacement kit for those years as well, which is flat.
Sometimes a small modification to the door cutout may be necessary when using these kits, but easily justified when you can save hundreds of dollars, or having a entrance door lock that works.
