Old 05-31-2019, 08:06 AM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Hitch Ball STUCK
2012 Eddie Bauer /
Made a weird clank when I dropped the Trailer on the hitch ball. Hitch lock went down and I locked it, proceeding as normal. Last night it I could not get the thing to release, grease, silicone, wiggling the truck back and forth, a little persuading with a hammer, no luck. Tomorrow I will be back in my summer home campground, and will pull the pin on the trailer, drop the chains and let the wretched thing hang. Any way to fix it myself, or does thia need a new ball receiver and lock welded on?
Paula, impatiently being patient. Understanding the concept of Zen, but resenting it,
Missing Panama Red's pithier post eners
Old 05-31-2019, 08:43 AM   #2
2019 27' Globetrotter
Salem , Oregon
Recently mine was the opposite. Would not go on the ball to latch. Would take me 30 minutes. No amont of lube seemed to help. I had to put a new kit in it works fine now. I am not sure maybee it was the spring.
I would pull the pin drop it as you suggested and spray lube in and let it set over nite.
Good luck.
Dave
NoResults is offline   Reply With Quote
Old 05-31-2019, 09:35 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have helped people with this before and spray lube is not the real answer, penetrating oil works better. Those things really rust/corrode and freeze up.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-31-2019, 09:37 AM   #4
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Paula unless something inside broke, after traveling again it may work fine for you.
It may just need a little tweeking. (Obviously)
While trying to unhitch if you have someone to step on the truck bumper and jiggle themselves around a bit that may work. We have put truck in park and then moved it slightly forward just enough to reposition it and then it came loose.
Good luck.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-31-2019, 11:44 AM   #5
gator.bigfoot's Avatar
KW , Ontario
Sometimes to much pressure on the ball will cause this. Try to see if you can relieve the pressure by backing up or leaving or vehicle in neutral. Just be sure to choke the wheels on the trailer and have someone inside you vehicle. The alternative is to pull the hitch pin in your reciever and pull out forward. The try to get the ball unstuck from there.
gator.bigfoot is offline   Reply With Quote
Old 05-31-2019, 11:54 AM   #6
Kensington , Maryland
Try adding a couple more jack pads to give the jack a better shot at pulling up. Been there done that.
Still learning
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 05-31-2019, 02:00 PM   #7
Thanks all. Tried most of that yesterday. 109° beat me down, and the thought of truing to drive the truck onto the hitch allowed me to surrender. Better luck tomorrow. Reserved a spot in the trees and lots of people.offer to help.
Worst case find someone with a Lincoln welder installed in his truck bed.
Paula, contemplating camping with Pedro in South of the Border, the tackiest place on.earth.
Old 05-31-2019, 02:14 PM   #8
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Hitch Ball STUCK
Paula
That’s about 1.5 hr away from me.
That’s a plan C offer
South of the Border, Tacky, really ?
Pedro says not tacky till you back into a cactus!
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 05-31-2019, 02:29 PM   #9
Gary TACKY isn't necessarily bad. Kitchy might be better. I have had more than a passing thought that it might be a fun place for a vintage and "faux vintage" rally. Best Lucy and Desi costumes, best 1930s bathing suits (when men were expected to wear singlets ("wife beater" undershirts) to avoid showing their nipples! And of course best fried baloney sandwiches, and molded Jello, and Waldorf salad (grrk apples, raisins, grapes, celery and mayo - grrk!) Of course tomato aspic for the truly masochistic.
And pink concrete flamingos everywhere.
Bleah, just spoiled my lunch.
Old 05-31-2019, 03:24 PM   #10
lsbrodsky's Avatar
To digress, we have stayed there a couple of times a year, on our way to and from Charleston. It really is a nice campground, especially since utilities are on both sides of the trailer. The food at Peddler's is pretty good, not so much anywhere else.
However, this year they increased the rates to almost equal with a KOA. Not worth the extra money!!
Larry
Old 05-31-2019, 03:28 PM   #11
GCinSC2's Avatar
Hollar if you need help.
Pedro
S/OS #001
Old 05-31-2019, 04:38 PM   #12
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The coupler latch may have jammed, which would probably need a new one installed. They are replaceable, though I wouldn't recommend a novice try it.
Old 05-31-2019, 05:23 PM   #13
Central , Mississippi
I've had the same thing happen. When you get home and pull the pin, it's likely that the hitch will come loose after you pull the truck forward. Don't put your toes under it. That reminds me, I need to get Fritos at the grocery.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 05-31-2019, 05:26 PM   #14
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I don’t want to know how you connected your toes with Fritos. I will say I make that same connection with Daisy’s paws but I just - I - well....I gotta go.....
Old 05-31-2019, 06:10 PM   #15
Long Island , New York
SSM,
. . . Free toes . . .
Phonetic . . .
Time for a paws, I guess.
Have a good weekend,
Peter
Old 05-31-2019, 06:14 PM   #16
Fried Spam!
https://www.google.com/search?q=Frie...com&gws_rd=ssl
Old 05-31-2019, 06:14 PM   #17
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , NC Highlands County, FL
When I had a hitch ball stick in the coupler, and jumping/bouncing on the bumper did not work, (first removed the WD bars) I put the jack foot down and took weight off until I could lift the latch lever. Then I lifted the rear of the truck a few inches, until the weight of the truck was hanging on the coupler. Then I stuck a long crowbar between the lip of the coupler and the ball mount. I was able to get enough leverage, with the weight of the truck assisting, to pry the ball out.
Once you get the ball out, you might find the space in the coupler latch area is filled with grit/grime/grease buildup. A good cleaning may be all that's needed. If something is broke or bent, installing a latch kit is not really hard to do, but it is messy.
ps:
You might take a photo or two of the area, looking up from beneath the hitch latch. If you post photos, someone might be able to see the problem and give a better diagnosis.
Alan
Old 05-31-2019, 10:14 PM   #18
2000 25' Excella
Northern , California
I had a similar experience, and was able to get it unstuck. Mine is an Atwood coupler. I lowered the jack to put the coupler in a completely neutral position with weight neither pushing down nor pulling up on the ball. Then I took a long screwdriver and easily pushed up on the retention mechanism on the underside of the coupler and hitch ball. At the same time, I raised the coupler off the ball, no problem. When I fully raised it, the internal mechanism fell out on the ground. At the time, Atwood was still in business, and the coupler repair kit was still available, less than $20 as I recall. It was a very easy, 5 minute replacement to put in the new coupler mechanism. If your's is an Atwood and you can find the coupler repair kit, it should be an easy fix. Unfortunately, the last I checked, the part is no longer made, and you may be S.O.L. with that coupler. You'll then have to cut it off and weld on a different make.
Kamiak is offline   Reply With Quote
Old 06-01-2019, 10:25 AM   #19
EXTREMELY GROSS AND GRAPHIC STREAM OF EXPLETIVES DELETED!
Gloom despair and agony on me. Deep dark depression, excessive misery.
If it weren't for bad luck I'd have no luck at all... (HeeHaw)
Sitting in a parking lot 110 miles from Va. Beach, just south of the NC-VA border looking at the hole where one of my living room windows used to be. Eddie Haskell Strikes again. The redeeming news? Screen is still intact. Trying to work up courage to go back and look inside.
Do I drive it home as is or try to find plexiglass and aluminum tape in locally? Leaving I-95 for VA 58, a 2 lane mostly rural road in 14 miles.
Old 06-01-2019, 10:36 AM   #20
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Duct tape, cardboard, extra duct tap.
Stop the wind from blowing inside.
Go home!
If it rains, stop for a while.
on edit:
If you are near a Lowes or HD, you could get a piece of plywood instead of cardboard. They will cut to fit.
Alan
High Rise Hitch Ball compatible with equalizing hitch setup? PA BAMBI II Hitches, Couplers & Balls 3 05-23-2018 08:56 PM
Stuck lever on release of ball Spinonedad Hitches, Couplers & Balls 19 12-11-2016 12:50 PM
Hitch Ball Alignment mnikisher Hitches, Couplers & Balls 39 08-09-2005 02:29 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
Hitch ball torque APB Hitches, Couplers & Balls 2 02-24-2003 05:13 AM
