09-03-2021, 07:34 PM
2018 30' Classic
Williamsburg
, VA
Help with finding shower door sealer
The plastic door trim that helps keep the water in on my 2018 classic shower door has ripped. It's not in the Airstream parts book they only list the complete door. I called the manufacturer today but left a message as no one answered. Any help to find this part number would be appreciated.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
09-03-2021, 08:31 PM
2023 27' Globetrotter
Williamsburg
, Virginia
Following this. Have the same problem on my 2019 FC 27. Also from the Burg.
09-03-2021, 10:14 PM
2002 19' Bambi
Lafayette
09-04-2021, 06:26 AM
2015 30' Classic
2019 22' Sport
Miramichi
, New Brunswick
I have the same problem on my 2015 classic. Does anybody know where to find a replacement strip?
09-04-2021, 07:52 AM
2021 23' Globetrotter
Northern
09-04-2021, 08:58 AM
2018 30' Classic
Williamsburg
, VA
Thank you, after reading this I'm thinking I'm not going to replace it.
2018 Classic 30
2012 F250 6.7l
09-04-2021, 10:49 AM
2019 25' International
Washington
, Washington, D.C.
Are you sure you need it? Mine was replaced twice under warranty. The last time it tore, I removed it and took a shower. No water on the floor! So I never replaced it.
09-04-2021, 11:06 AM
Evergreen
I didn't replace mine after it ripped. I have no issues with water leaking outside the shower.
Dennis
Past:
Airstream International Serenity 23FB
Newmar Ventana 3715
09-04-2021, 11:35 AM
2014 27' FB International
Lewisville
My door did leak onto the floor without the strip. I fixed it with this five years ago, it works perfect. https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
09-04-2021, 12:07 PM
The Silver TARDIS
2018 30' Classic
Hillsboro
, TX
Part numbers
Here are a couple of part numbers we have needed more than once:
703911-100 shower swipe
360371-301C (Alde fluid: Light Tiffany)
09-04-2021, 04:05 PM
Freedom
2023 30' Classic
Dallas
, TX
Mine ripped in the first year of ownership. My dealer had to put spacers in the hinges to slightly raise the door. It has been fine since then. You might want to give Airstream a call and see if they will ship them to you. I understand they are very easy to install. This prevents the door from pinching the sweep, which causes these issues.
2023 30 Foot Classic
2022 Ram 3500 Dually
09-04-2021, 04:28 PM
2018 30' Classic
Williamsburg
, VA
Originally Posted by NO NOIZE
I can't get that link to work.
2018 Classic 30
2012 F250 6.7l
09-04-2021, 04:31 PM
2018 25' International
Full-time
, Traveler
I replaced mine twice and then gave up. It seems to work better without it. No drips at all.
09-05-2021, 12:19 PM
Lewisville
For some reason the Airforums link is changing something. Take the below URL and copy and paste it into google
https://www.amazon.com/Translucent-V...0865841&sr=8-2
Or this one:
https://www.amazon.com/Translucent-V.../dp/B0149IL0HU
Also try the links on a laptop instead of a phone.
The product description is:
"CRL Translucent Vinyl Edge "L" Seal with Pre-Applied Tape for 3/8" Maximum Gap - 95 in long"
09-05-2021, 04:32 PM
2018 30' Classic
Williamsburg
, VA
Thank you I got the search to work. For now I took out the ceiling edge and then cut the part that swipes the water off. Then reinstalled just to ensure no moisture got up in the door. So far it might actually be working better.
2018 Classic 30
2012 F250 6.7l
09-06-2021, 11:25 AM
Lewisville
The factory sweep / seal installs into the bottom channel of the door and extends down (vertically) to touch the top of the fiberglass floor sill. The plastic is too ridged and eventually breaks off.
The CRL strip from Amazon installs with a tape strip on the inside bottom of the door with the strip facing inward (horizontally) guiding the water from the door back into the shower. It does not touch anything so it seems to last for ever.
09-12-2021, 09:35 AM
Dreamin Bout Airstreaming
2019 27' Globetrotter
Savannah
, Georgia
Please show us a photo of how yours is installed. Thanks
09-12-2021, 09:42 AM
Providence
, Senior Electrical Engineer
I'd like to see this as well.
09-12-2021, 10:18 AM
2019 25' Flying Cloud
Sequim
Originally Posted by JEB
Thanks! I was also searching for this for my 2019 25 FBT. Though I had no drips after removing it, I prefer to repkace it.
The above link worked perfectly and took less than 1 minute to order.
09-13-2021, 06:35 AM
2018 27' Globetrotter
paris
, Tennessee
shower door seal
go to hardware store and buy 3/8 wide x 1/4 tall foam insulation in a roll
sticky on one side about $3. clean and dry the threshold and apply foam
to bottom of threshold NOT the door, Take the original plastic strip completely off. The foam is also handy for other things. Keeping out drafts at door,
where doors strike, good luck. Easy to replace after a year or so (if you can
find the roll again
