Tried inserting a small pin in the what looks like a hole in the handle? Home locks frequently use a small blade to turn internals and release and don't some just push a pin in?
2017 27' International
Antes Fort
, Pennsylvania
Thanks all. Phew! I forcefully turned the door handle up and the door popped open! What a relief. Next project is to buy a bathroom door handle that doesn't lock. I really don't need a lock on my bathroom. Thanks for your contributions.
Before you go out and buy a new handle, check the little hole in the middle of the handle that shows in your photo. I do believe that a paper clip or something similar will unlock it.
We have a 2018 Flying Cloud 25FB and our toilet room door latch started to do the same thing with the door latch not opening until it finally failed. After searching a few other forum threads it looked like I needed to replace the entire handle set or find a flush pocket door replacement. I had a hard time finding one that would work with the metal shield.
Then I found a Entry Door Latch from Kwikset from Lowes. And bingo that worked with the original handles. The cost was $7.98! This was for an exterior door but worked just fine indoors.
