Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 09-06-2002, 07:36 PM   #1
Road Ruler's Avatar
St. Catharines , South Western Ontario
Images: 38
Unhappy Door Seal Types ???
Hello Folks
I have spent the last two days aligning our bent door as per the good instructions by a number of you folks. I got it back to the original shape and looked good until I installed the new door seal. Now the door is a quarter inch out from being flush with the frame. The new A/S seal seems to thick. I stopped at a friend place tonight and had a look at his 72 Argosy. His door was flush and has the original seal that was very different from the one I installed on my "73" 23 ft Safari.
His seal was 'L' shaped where my new seal has two blades coming off it at an angle. My new seal is like the one I took off and I am wondering if it was the wrong one and was the reason the door did not fit flush and pulled out at the top and bottom???? Any info is appreciated.
Road Ruler is offline   Reply With Quote
Old 09-06-2002, 07:44 PM   #2
Wayne.
The double lip gasket was used on the doors from 64 to 73. In 74 the gasket changed.
I will be gone until Wednesday, but if you could e-mail a couple of photos, I will try to help you when I return.
inlandrv.com
Airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-06-2002, 07:52 PM   #3
Road Ruler's Avatar
Images: 38
Door Seals
Thnxs Andy...
We too are heading north near Algonquin til Wednesday with the trailer. Will see if I can get some pics of our door. The door looked so good before I put that *#@#@$%^& gasket on. I just seems too thick. Anyway it will keep the rain out on our trip.
Old 09-07-2002, 05:53 PM   #4
niftypkg's Avatar
1971 27' Overlander
Cornville , Arizona
Unhappy Door seals
Just went through that. My door was out about 1/4 inch top & bottom before and after I installed the same new double lip seal that you installed. I'd like a flush door but the cure may be harder than It's worth.
Tom
niftypkg is offline   Reply With Quote
Makes? types? Models? tenrsingr 1970 - 1973 Sovereign 8 12-08-2005 02:41 PM
KLM and other types of 'Resort Packages' JodynJeep On The Road... 11 10-18-2003 12:11 AM
Types of patio awnings Coloradobus Awnings 4 09-04-2003 05:22 PM
Rivet Types lee Ribs, Skins & Rivets 2 08-02-2003 07:59 AM
