Old 04-08-2020, 06:21 AM   #21
M. Smith's Avatar
2020 27' International
Tuttle , Oklahoma
I didn't have a notched wedge like in the video. Used a regular wedge and put some electrical tape on it for cushion. I was pretty timid with the pounding at first, but wasn't denting anything so hit it harder. I couldn't tell that it was moving at all, but it definitely moved enough to make the latch work better.
Before, I could see that it was slightly off center. Had to really slam it to make it close and it was difficult to close from inside. Works great now.
M. Smith is offline   Reply With Quote
Old 11-02-2021, 07:04 PM   #22
Life is a Highway's Avatar
2021 30' Flying Cloud
Airstream - Other
Airstream - Other
Lady Lake , Florida
Lucky you
Lucky you our 2021 upper hinge bolts both just spin in circles even pulling on the hinge. Must be the tack weld or something broke loose on the inside. Not to mention the factory stripped out the torz bit bolt holes. Called the factory they said start drilling out the interior.
Originally Posted by Kalashnikov View Post
Ok problem solved!
- I tightened the heck out of both screws, they seem solid now
- Replaced the adhesive on the plastic 'chrome' piece with a fresh strip of 3M VHB tape
Life is a Highway is offline   Reply With Quote
Old 11-02-2021, 07:18 PM   #23
Airstream - Other
Airstream - Other
Lady Lake , Florida
Thank Bob
Thanks for the link. Picture helps. So with our 2021 30 ft the bolts are just spinning in circles must be someone on the line forgot the bracket or they quit using them. I can push and pull my bolts out 1/4 inch but can’t tighten them. Has to be they just used nuts ?
Herv
Front door upper hinge pin Beach Bum Windows, Doors, Locks & Vents 15 05-27-2014 04:08 PM
Door Hinge Pin loose deauxrite Windows, Doors, Locks & Vents 13 01-14-2014 07:52 PM
'78 Sovereign needs upper door hinge sharris1199 Doors & Locks 0 09-07-2009 07:25 PM
Door hinge come loose turfclubroad Exterior Storage Compartments & Access Doors 0 09-01-2009 10:13 AM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
