Old 06-22-2024, 04:27 PM   #1
2024 20' Caravel
Westerville , Ohio
Deadbolt will not lock
2025 Caravel 20FB - deadbolt worked fine until today. Now, when I try to lock it, it will not go into the lock position. When door is open, deadbolt moves fine, but when I shut the door and try to lock it, it will not lock. Per my dealer, I give the door a good slam, and I push in the door when I turn the deadbolt. But now it’s not working. Any ideas?
CopyPirate is offline   Reply With Quote
Old 06-22-2024, 05:01 PM   #2
2019 30' International
Pennsylvania , Pennsylvania
Some times an Airstream will sit crooked on a site, or maybe the stabilizers are down too tight....so the doors not quite sitting in the frame square. These things have some flex. Check the latch too, make sure it hasn't been damaged, loose, or moved around.
Smear some grease on the deadbolt, close the door, twist the deadbolt to lock, then open. Open the door and see where the grease hit the door jamb....or use some other marker in such manner to get an idea how far off the deadbolt is from the latch plate.
And then there's grease. I always have a wee dab of grease on the door latch post, the latching mechanism, edges of the deadbolt latch plate etc.
Edit to say....check the main door hinges too, make sure they're not loose.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 06-22-2024, 05:16 PM   #3
Master Chief BT
BTCMUSN's Avatar
2018 27' International
Tyler , Texas
So what happened with mine is that repeated “slamming” of the door with the deadbolt out possibly causes the deadbolt mechanism (a stamped and tabbed box) to push the tabs apart and the actual dead bolt gets slop in it and degrades the in/out movement of the dead bolt.
A couple of large head rivet removals and you can pull the dead bolt actuator out (includes that box with tabs) and tap the tabs back together (actually I tacked the tabs too with weld tacks) to tighten up the dead bolt actuator….or…..just buy a new dead bolt actuator and install that to your current keyed deadbolt so no keys have to change. I’ll check to see if I have pictures of what I am describing above. It’s easy to damage that actuator with some accidental door slams with dead bolt out partially.
That’s what mine was..
2018 International Signature CCD 27FBQ/Centramatics/Hensley Arrow/16” Michelin XPS RIB/TST-GM TPMS
2024 GMC Sierra 2500 AT4 DURAMAX/Trailer Tech PKG/Transparent Trailer Camera/Centramatics
WBCCI#11290
US Navy (ret) Master Chief Boiler Technician
BTCMUSN is offline   Reply With Quote
Old 06-22-2024, 05:16 PM   #4
Rich Jenkins's Avatar
2019 25' Flying Cloud
Ocala , Florida
When you close the door from the outside, pushing firmly with your palm on the deadbolt, do you hear one click or two? If one, the door is not fully home and the deadbolt will not work. Try pushing hard, so you hear two clicks. In theory, you should not have to slam an Airstream door.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Rich Jenkins is online now   Reply With Quote
Old 06-22-2024, 05:25 PM   #5
Master Chief BT
BTCMUSN's Avatar
Tyler , Texas
https://www.airforums.com/forums/sho...errerid=151937
Try this thread…this is what happened to mine.
WBCCI#11290
Old 06-22-2024, 09:06 PM   #6
2017 28' International
Jim Falls , Wisconsin
Mine wouldn’t close either when I first got it. Just had to work it back and forth with some lube on it. Now it works fine.
Daquenzer is offline   Reply With Quote
Old 06-23-2024, 07:37 AM   #7
MRA
2023 25' International
Alameda , California
Ours suffers from deadbolt and other door close failures all the time. It’s so far been all warranty repairs. Now that my trailer is over a year old, I am expecting push back - we did discuss lemon law with the dealer since that particular thing has been fixed no less than 6 times since the trailer was new.
I know this doesn’t help solve your problem, but at least you know that you are not alone.
MRA is offline   Reply With Quote
Old 06-23-2024, 10:16 AM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
The screws holding the deadbolt in the door will loosen over time, which will affect its alignment. Make sure they are nice and tight. If it used to work, that should make it work again, unless it was damaged.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
Hermes is offline   Reply With Quote
Old 06-23-2024, 11:13 AM   #9
2014 27' FB International
Lewisville , Texas
Repair Video
Here is a Video of a repair like the one in the link in post #5 above.
I saved this for future reference, it is very well done.
NO NOIZE is offline   Reply With Quote
Old 06-23-2024, 01:15 PM   #10
daleyocum's Avatar
2018 25' Flying Cloud
Portland , Oregon
This really is the right way to fix it and likely what’s wrong. All it takes is one time slamming the door with the deadbolt accidentally extended and it will need repairing.
I needed to fix this on the road and didn’t know how to take the door apart (I do now.) My field repair to to make a little 1/8”-3/16” thick “T” shaped shim out of plastic (lexan/acrylic) that slid in on the right hand side next to the deadbolt to take up that extra play that developed and convince the deadbolt to go back where it’s supposed to be. It works fine but not as classy as doing it right like this video shows.
daleyocum is offline   Reply With Quote
Old 06-23-2024, 02:23 PM   #11
2019 25' Globetrotter
Naples , Florida
When setting up stabilizers make sure the frame is not twisted because you have them too tight. Back off on the tension a little. You should not have to slam the door to close it. If you do then the door needs to be adjusted. Ronnie from Airstream Nuts and Bolts demonstrated how the door should close with two clicks. If the door doesn't completely close the first try you just push it gently to get the second click.
nickjules77 is offline   Reply With Quote
Old 06-23-2024, 07:21 PM   #12
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Lots of great information in this post. Thanks for the additional thread and video.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-24-2024, 08:03 AM   #13
2019 25' International
Washington , Washington, D.C.
If your stabilizers are tightly pressed to the ground raise them a bit and see if the lock works. Also, it's not necessary - despite the ubiquitous advice of AS dealers everywhere - to slam your door shut. In fact, if the deadbolt is unintentionally left extended, slamming the door could really do some damage.
PatLee is offline   Reply With Quote
Old 06-24-2024, 08:06 AM   #14
MRA - you have a 3-year warranty. If your travels take you anywhere close to Jackson Center, stop in at the factory to see if they can permanently fix your problem with the door. After all, they make the doors, in-house.
Old 07-03-2024, 05:09 AM   #15
MMCMRET's Avatar
Deadbolt Pictures
I just completed repairing the deadbolt. Using my endoscopic camera I took a picture of the damaged deadbolt, in the door, before I removed it. Getting it out was a challenge due to the damage.
Name:   Lock (broken) inside door.jpeg
Here is the deadbolt assembly after it has been removed and repaired.
Name:   Lock (repaired).jpeg
The re-instillation was very easy.
Todd Mizer
Ford F-250 6.7L
WBCCI #6826
Old 07-07-2024, 09:31 AM   #16
2019 33' Classic
Wellington , CO
I had this issue with my Classic last year. The ground where I was parked was soft so that when I lowered the stabilizers it kind of torqued the frame causing the deadbolt to not release. Everything turned out fine when I raised the legs.
Now my wife is scared to set the deadbolt under any conditions :-)
rheston1947 is offline   Reply With Quote
Old 07-07-2024, 10:10 AM   #17
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
The TEST before using other Options
When you close the door and inside the trailer... have you tried to use the manual lock? If it works and easy, that is good. New Airstreams have unused door gaskets that actually seal well. That will change over time.
Pull the handle inside hard enough to close and lock, the pot metal handle can break and you become a mechanic.
Break the key off in the mechanism, fiddling on the outside... you become a mechanic.
We do LOCK the DOOR while moving and towing to secure. In the event you have the door up front that could open and rip off onto the highway. The Rear door model hinge swings opposite, so not as big a deal.
There is no slop in the locking mechanism itself. It is the mounting screws job to fiddle around. If you have to push the door a bit to lock it with a key outside... that is GOOD.
The door seals will keep dust getting into the trailer, if ever on a dirt road. Even not, that is GOOD.
Why lock the door while parked? Someone can open it with a crow bar and take something out of your trailer? Expensive door damage by a thief. Not worth locking up tight and then cannot even close the door with all of the damage?
PUSH the door at the edge, snug against the flexible gaskets, twist the key. Snug is good. When unlocking, PUSH at the edge of the door, unlock. Snug is good.
Once you start fiddling with the two big screws on the outside edge and the three holding the lock assembly... you are up a Creek without a Padlock.
After 18 years never locking our trailers... nobody likes any of the contents we carry. A Travel Trailer is not like a RV where they can hot wire it and drive off. But where do the bad guys go? Not too far.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 07-07-2024, 03:27 PM   #18
Primo
primotenore's Avatar
2024 30' Classic
Danville , Indiana
The deadbolt on our 2023 FC would only fully engage if we leaned against the door. Our old Bambi never had that issue. QC is the issue, IMO. If it were my Airstream, it'd be back at the dealer for a warranty repair.
Primo
2024 Classic 30RBQ
Danville, Indiana
primotenore is offline   Reply With Quote
Old 07-07-2024, 05:10 PM   #19
2017 19' International
Tallahassee , Florida
This has started happening with our 2017 19-footer. Worked fine until recently.
Anyone have ideas on how to adjist?
WhereStream is offline   Reply With Quote
Old 07-08-2024, 07:15 PM   #20
Fayetteville , Arizona
With my first and second airstream, I never had a problem with the deadbolt. With our new 2023, 28ft international I think we were just lucky it never happened before. On the first trailer, I was told you always need to slam the door to make sure it latches properly. NOT TRUE. On the second trailer, it closed more easily. 2 clicks. On my current trailer, the service department was close to closing during delivery of the trailer and brought it out of the shop and slammed the door with the deadbolt extended. Once you do, it is very likely that it will push the bolt inside the slide, away from the trailer. Always check to insure visually the deadbolt is retracted… then open your door and look at how the deadbolt travels while you extend it by using the key. If it comes out straight, it’s probably just a matter of pressing the door firmly and hearing 2 clicks before locking. If it comes out towards you slightly away from the trailer at an angle, you either have to take it out and try to repair it or have the lock replaced. If you’ve never done it before, it can be a pain in the butt. The new lock cost somewhere around $95 plus tax if it is beyond repair. There is a video online that makes it look easy, but it doesn’t actually show you what you’re doing after you take it out to repair it.
In my case, the dealer had to fix it so I didn’t take delivery until they did. I picked it up in North Carolina where I live. And I drove to Florida and had a problem in Jacksonville., Fl. I called a guy named Phil Enoch in Cape Canaveral and on the way to Tampa to make the repair to the current deadbolt. Literally, a few months later, my wife slammed the door. I walked over and looked at the lock, and it was bent again. I removed it to fix it because I had watched Phil do the repair. But repairing it twice was not gonna happen so I had to buy a new deadbolt lock.
Lesson learned: if you’re traveling with the wife or Significant other, Visually show them exactly what you want them to do to make sure they don’t slam the door with the deadbolt extended. Make them actually turn the key so they have a visual of what happens to bend the deadbolt. LoL
akarakos is offline   Reply With Quote
Deadbolt Lock - will not lock due to pin strike point PSU1981 Doors & Locks 23 06-05-2022 04:54 PM
Help - Deadbolt Lock won't lock PSU1981 Windows, Doors, Locks & Vents 1 11-21-2016 12:04 PM
Installing a new deadbolt lock Moonshot Doors & Locks 7 10-08-2007 03:44 PM
deadbolt lock John Greenlee Windows & Screens 2 07-10-2004 09:33 AM
deadbolt with inside twist style lock CindyH Doors & Locks 4 10-16-2002 08:58 PM
