Old 08-29-2018, 12:11 PM   #21
1988 32' Excella
2000 35' Land Yacht XL w/2 slides
Cleveland , Tennessee
Broken lock
Our key operated deadbolt lock jammed or return trip from Salem locking us out or our trailer (1988 Excella 32-MB). Called locksmith who tried everything, then we jimmied open the window by the door, cut the screen & he had to get a pair of channel lock pliers & twist the inside thumb latch until the lock 'popped' open. Deadbolt had broken in shut position. Tried to remove the inside thumb latch & get the lock out but to no avail. May have to get local locksmith to help replacing lock.
kritenour is offline   Reply With Quote
Old 08-31-2018, 10:34 AM   #22
1985 31' Excella
Nashville , Tennessee
I thought I would add picture while I have deadbolt open.
Mine looks just like your on outside. Doing full restore and just removed my deadbolt to have keys made. The deadbolt is attached to the Handel with 2 screws and the Handel to the Airstream with four bolts. I removed the lock without removing the mechanism in the wall by grinding down Allen wrench. Click image for larger version
ID:	321230Click image for larger version
ID:	321231Click image for larger version
85airstream is offline   Reply With Quote
Old 09-02-2018, 09:34 AM   #23
2016 28' Pendleton
terre haute , Indiana
Yes. Spray the heck out of it with penetrating oil and let it sit for awhile. Work the key in and out. Move the trailer In case it is bound. It could be broken. More likely seized up.
jcwall is offline   Reply With Quote
Old 09-02-2018, 02:11 PM   #24
1991 29' Excella
Livermore , California
Deadbolt stuck
I have a 91 Excella 29’ which has the same lock. I have had occasional trouble with the deadbolt which is due to binding problems due to twists and pressures on the door. Have solved them all by applying various inventive pressures to the door. You need at least two people to help. I’d also try some lock lubricant, silicone or graphite.
dennisv is offline   Reply With Quote
Old 09-04-2018, 01:29 PM   #25
mrsretail6's Avatar
2003 19' Bambi
2017 23' Flying Cloud
Springdale , Arkansas
Just Fyi: My tumbler in my (2003 Bambi) door broke , and I could not get the key to work. Emailed the Jackson Center, and they told me to order a whole new door mechanism from a Airstream dealer. The door handle plus 3 sets of extra keys ran $200.
mrsretail6 is offline   Reply With Quote
Trouble with deadbolt and door lock Goingcamping Doors & Locks 2 09-06-2017 05:46 AM
'66 Tradewinds Lock Set and Deadbolt Questions maggieevans Doors & Locks 12 07-23-2013 08:06 PM
Deadbolt gets stuck! kds Doors & Locks 1 02-25-2013 07:22 PM
Outside handle, Deadbolt and Doorbells! Keyair Classic Motorhomes 14 01-23-2012 06:19 PM
Lockset and Deadbolt for '65 retronotold Doors & Locks 6 10-03-2010 01:23 AM
