Old 01-16-2022, 06:18 PM   #1
2019 25' Flying Cloud
Pala , California
Dead Bolt Key Worn But....
Hi,
SO the original brass key is worn pretty good but still locks and unlocks the deadbolt BUT it can unlock it without being fully inserted. In fact I have to fiddle with it to make sure it's locked or it could spin/unlock with a screw driver.
The unused original spare is more snappy and when using it it doesn't behave this way. I lock it and it's locked!
Why would a worn key do this? You'd figure it'd not work at all.....
Removed, cleaned and lubed the lock and worked the newer key numerous times to perhaps loosen a tumbler. I thought maybe there's only one tumbler actually locking allowing a worn key to work.
Not comfortable as-is. Not sure if I should replace the lock or perhaps it's under warranty still (2019 FC bought in 2020).
Would this be an Airstream part? Or perhaps I can find the brand and buy cheaper elsewhere if need be?
Thanks!
Trav
TravisH is offline   Reply With Quote
Old 01-17-2022, 11:13 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Might be warranty. Check with dealer, either way they will need to order the part for you assuming you want to stay OEM. They may just replace the key for you?
I’m not sure what kind of aftermarket options exist.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 01-17-2022, 11:51 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If your key is worn, make a copy of the spare and get rid of the worn one.
Richard
Dead Bolt key broken off. bwaysteve Doors & Locks 15 05-19-2017 11:56 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Dead Bolt Key 1988 Excella 32"-0" View Doors & Locks 2 05-17-2009 09:27 AM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
1983 32' Classic Dead Bolt worn out Kajendo 1982-1983 Limited 5 01-12-2004 03:37 AM
