Cast Door Contour Problem
Here's what [had] happened...
The entry door on my '69 was a mess. L-100 was a mess, there was a cabinet drawer lock installed as a "deadbolt". The interior/exterior skins had swiss cheese holes from someone doing god-knows what--a mess.
Removed all the locks. Rebuilt the L-100. Patched the exterior skin. Reinsulated the door.
I used the old interior skin as a template and cut a new, one-piece interior skin. I used a strap duplicator to reuse the existing interior rivet holes in the cast door. Then, I installed the interior skin using clecos and riveted in place. I tried to work my way evenly up/down the door when drilling and cleco-ing the interior skin in place.
Here's the problem. The contour/curvature of the door no longer seems to match the trailer at the top, font corner--it is probably 5/8-3/4" away from the door frame. I never noticed this problem prior so I'm assuming that somehow I managed to ever so slightly pull the door out of alignment during the installation of the interior skin. Since it is a cast aluminum door frame, it didn't occur to me that this could happen.
I'll take the interior skin off this week and see if the door springs back into the correct shape--my guess is that it will. Assuming that's the case, when I reinstall the skin, how do I keep this from happening?
Any other ideas on what I did wrong or how I can correct it?
matt.
