Bargman L200 Lock
I have a L200 lock that is having a issue when I try to lock it. Took it apart and cleaned all the parts and reassembled. The slide that the spring and ball bearing sit in will not move when I try to unlock it with a key, screwdriver pointing at the piece in pic, it will move using a screwdriver to push the ends. It did the same thing before cleaning. The slide will move if I remove the spring and ball bearing. I have attached a pic of the slide I am talking about. Any help would be appreciated. The lock works great but has the issue trying to lock. I also need the #7 handle spring if anybody has a spare, pic included not sure if this may be part of the problem. Any help would be appreciated.
