Old 04-26-2023, 12:51 PM   #1
Stevenage , Stevenage
Ambassador break in - Replacement door
Hi all,
Unfortunately someone decided they wanted to break into an empty Airstream and in doing so destroyed the the entrance door.
Unable to find someone to repair (not many Airstream specialist here in the UK) I am now looking for a replacement door. It's a 1972 Ambassador
If anyone can advice id be most grateful
Keith
ID:	430742   Click image for larger version
KMC10 is offline   Reply With Quote
Old 04-27-2023, 04:41 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
It should not be super difficult to find a door from a donor vintage trailer, but it will likely be a search that requires a lot of patience. Being that you are in the UK, it will get expensive. Seems like the going rate for used vintage doors used to be somewhere in the $600 range. Shipping would likely be hundreds as well.
I have rebuilt my door, and although it was no task for the casual DIYer, it wasn't rocket science. I built wooden jigs that matched the curvature of the shell's door jamb, then removed the skins from the inside and outside of my door, and fitted it to the jig, then worked it until it maintained the shape. I then sourced replacement aluminum sheets and riveted them back into place with the door clamped to the jig to ensure the shape was maintained. Getting the accurate curvature is key.
good luck!
Old 04-27-2023, 07:05 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I'm not sure if you have a cast door frame or not, my 71 is cast. My door frame was broken or cracked in several places. As said above, remove the skins on both sides and start the repair. Cast frames can be welded and skins replaced. Finding a replacement may take a while. Depending how handi you are it can be a fulfilling project.
Sent from my Lenovo YT3-X90F using Airstream Forums mobile app
break away switch replacement jsmall01 Brakes & Brake Controllers 17 12-21-2020 07:44 AM
Leaking Vacuum Break for toilet - where to find replacement grapevine_tx General Repair Forum 1 04-07-2019 12:36 PM
New Door Seal Break-in Time HiJoeSilver Doors & Locks 9 05-25-2015 06:28 PM
'75 Safari - just had the door handle break off ronstory Doors & Locks 2 07-13-2008 02:51 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 09:22 PM
