Old 09-26-2020, 05:40 PM   #1
Indian Rocks Beach , Florida
Always need to slam the door
I have a 2021 Globetrotter 25FB. Every time I need to close the door I need to slam it. Something is wrong and I canít tell what the problem is. Any suggestions?
This is my 2nd RV but first AS.
ortsa is offline   Reply With Quote
Old 09-26-2020, 05:41 PM   #2
Phoenix , Arizona
This is pretty common. I have the same trailer and had to give a decent push at first. It has gotten better of 12 months or so. Congrats on a great trailer.
PhxTrotter is offline   Reply With Quote
Old 09-26-2020, 05:46 PM   #3
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We have a 2004 international yeah the door requires a good push
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 09-26-2020, 06:00 PM   #4
2012 28' International
Prince Edward County , Ontario
We had a similar problem on our new 2012 Airstream and apparently it's relatively common. There is a fix and our dealer did it under warranty - the door can be bent to fit. Now we only need a slight push to close the door.
Cyclist is offline   Reply With Quote
Old 09-26-2020, 06:03 PM   #5
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Flat hand over the dead bolt lock, close FIRMLY. Standard Airstream procedure.
2019 Ford Expedition Platinum
Old 09-26-2020, 06:20 PM   #6
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Too much pressure on stabilizer under the door?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 09-26-2020, 07:32 PM   #7
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
I think this is a problem more likely to happen to longer trailers. I have a 2017 International that when I park it on it's home concrete pad it is happy and the door closes with two fingers. It's a different story when I am settled in a campsite. The frame must twist just slightly - enough to cause the door frame to bend making it more difficult to close. If I fuss with the stabilizers a bit it settles down and the door closes easily. I also noticed my screen door is not exactly closing smoothly so when I get a chance to play with it I'll try to make it close properly. These things are hand made and need some tweaking to get then right.
VaTravelers is offline   Reply With Quote
Old 09-26-2020, 08:01 PM   #8
2020 27' Globetrotter
Greater Salt Lake City , Utah
We have the 2020 GT 27 ft and have the same challenge. Not that difficult but does require firm pressure to close.
More challenging closing from inside without slamming given the single handle.
ExploreUT is offline   Reply With Quote
Old 09-26-2020, 08:13 PM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
The latch inside the door is about 1/8th too low against the strike bolt on my trailer (2017 30í)
2 things I did that helped:
1. Tightened the screws holding the door hinges to the frame (they were loose)
2. Put a little grease on the struck bolt.
I donít slam the door. I close it by applying pressure from my hand / pressing firmly over the latch area as noted above.
When you do so on my unit you can see that the door raises slightly as it grabs the strike bolt.
wulfraat is offline   Reply With Quote
Old 09-26-2020, 08:21 PM   #10
2018 27' Globetrotter
Mooresville , North Carolina
27í Globetrotter. Lubricate latches / strike bolt with silicone. I think the main thing is to make sure RV is level and use stabilizers.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Weight Distribution attached to the Gen-Y Torsion Flex Weight Distribution Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 09-27-2020, 06:17 AM   #11
2019 25' Flying Cloud
Houston , Texas
The dealer made ours close better under warranty, but it still requires a pretty good slam.
DCPAS is offline   Reply With Quote
Old 09-27-2020, 06:41 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Level the trailer, raise all the stabilizers, try it now.
Frame twist from too much "stabilization" is the most common cause.
Door is twisted...time to at 6:50 👍
Tahawus
Love for the Adirondacks
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 09-27-2020, 07:15 AM   #13
dznf0g's Avatar
Oswego , Illinois
This may be unique to my unit, but I have noted that if I start with the RR stabilizer, followed by LR, then LF and finally RF, the door works well first time. I use setting #16 on the makita clutch to ensure the same force is on each stabilizer.
-Rich-
Old 09-27-2020, 08:06 AM   #14
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Our son had the same problem with his door when he came to visit this summer. The problem was the strike bolt was sticking out too far from the frame and catching inside the latch. He removed a washer between the strike bolt and the frame, and it solved the problem.
Kay
Old 09-27-2020, 08:07 AM   #15
Minno's Avatar
1972 31' Sovereign
His trailer is a 2020 25 ft FB Sport.
Kay
Old 09-27-2020, 09:24 AM   #16
greenflag's Avatar
2016 30' International
Quartz Hill , California
If you crank your stabilizers down too tight you can actually tweak the shell just enough. Do not use them to get that last little bit of leveling.
greenflag is offline   Reply With Quote
Old 09-27-2020, 09:50 AM   #17
2019 Nest
Omaha , Nebraska
We have a Nest, small trailer, so not sure if it’s size, same issue, resulted in the interior fiberglass door panel getting a small crack near the door handle. Jackson Center replaced entire door. We do have to make sure perfectly level which helps. Also lubrication as stated above.
2019 Airstream Nest
2018 Chevrolet Silverado 1500
Beboplu is offline   Reply With Quote
Old 09-27-2020, 09:58 AM   #18
I do the same thing exactly...except different.
Most of the time I don't use the front stab's at all. I find if the rear don't rock the front won't rock.
Tahawus
RLC
Old 09-27-2020, 10:40 AM   #19
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
2016 25' Flying Cloud
Bandera , Texas
Never slam. Youíll pay later with door handle and or lock issues.
banderabob is offline   Reply With Quote
Old 09-27-2020, 10:45 AM   #20
1997 25' Excella
North Saanich B.C. , B.C. Canada
Harry the horse
Iím not sure on the newer A/S but if yours is a few years old it may be because the door hinges are Aluminum and the washers are steel. This set up a reaction the caused the washer to decay. I had the panel taken off a replace the washer with a type non steel. Now the door works perfectly
Harry Horse is offline   Reply With Quote
Entry Door - Don't slam it! cbburke Airstream Trailer Forums 7 02-20-2019 03:52 PM
Have to Slam the Door on a New AS? ltorgy Windows, Doors, Locks & Vents 53 04-26-2017 08:09 PM
Why do I have to slam the heck out of my door?? MOS General Repair Forum 32 03-10-2016 11:15 AM
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
