09-27-2020, 01:21 PM
#21
Stay CazuaL
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda
I added a secondary handle on the inside so I don't have to use the main handle. I can't port external links, but PM if you want to see it.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
09-27-2020, 01:41 PM
#22
2019 25' Flying Cloud
Houston
Originally Posted by banderabob
Never slam. You’ll pay later with door handle and or lock issues.
We use the handle on the screen door to close the door in order to avoid door handle issues.
09-27-2020, 02:38 PM
#23
2016 28' Flying Cloud
Colorado Springs
We have a 2016 28' FC RQ, and when we first got it we had that problem. I noticed the striker bolt was too high on the frame and you had to lift and slam the door. So I loosened the bolt (not all the way!!), drilled out the rivets, slid it down about 1/8", drilled new rivet holes, tightened bolt and put in new rivets. Now it shuts like a high $ auto. Just close, clunk, done. No more slamming. With how many AS have this issue, I think the jig they use at the factory is out of alignment.
Don & Karen
2016 AS Flying Cloud 28'
2019 GMC Denali HD, Duramax
09-27-2020, 03:33 PM
#24
2018 30' Classic
Williamsburg
, VA
We had this on our trailer and had it repaired under warranty. The door was either too large or not bent right or something because it was hitting the top of the opening and scratching and caused a crack. When they first did the walk through with this they said yes it's normal but then later fixed it under warranty. it still requires a good push but nothing like it did before.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
09-27-2020, 04:32 PM
#25
2020 16' Basecamp
Louisville
, Kentucky
Part of the charm
One year in on our BCX and same issue. I just thought it was part of the charm of a TT.
09-30-2020, 08:26 AM
#26
2020 28' Flying Cloud
Jax Beach
The door on our FC 28 sits a little low so that the latch and the strike don't line up well. I put 2 small nylon washers under the door part of the hinge, where the door rides on the trailer mounted part of the hinge. It raised the door by about 1/8" and the door now closes fine. I cut a small notch in the nylon washer to allow me to slide it beneath the door portion of the hinge while lifting up on the door. It lets me get it onto the hinge pin without removing any hardware. The fix lasts about 6 months before the nylon washers deform and fall out, but at a few cents each and 5 minutes install time it works for me.
09-30-2020, 08:44 AM
#27
2021 23' Globetrotter
Somewherein
, Pennsylvania
I have heard to always close the door together with the screen not the screen then the door.
10-01-2020, 09:11 PM
#28
2017 30' International
Broomfield
Always need to slam the door
^^^^ smart. My next mod. I am low on the strike bolt by 1/8” and this is a great path forward.
10-01-2020, 10:08 PM
#29
Freedom
2020 25' Flying Cloud
Dallas
, TX
My 2020 25 footer is in the Airstream shop for repair right now. One of the issues I've had since the day we took it home is the dead bolt lock would NOT lock from the inside, but it would from the outside as we pushed in on the door harder. They say it is fixed and I pick it up tomorrow. I'll find out exactly how they fixed it and let you all know. It may possible be doing what is shown in the video above, but I will verify if that is the case of not.
I basically put the stabilizers down until they touch the ground. I use pads and I simply lower then until they touch the pad and then I stop. I fully understand the whole frame twisting issue.
10-01-2020, 10:37 PM
#30
Newport Beach
I was told by my dealer to only use the deadbolt when I am parked. He said a common problem with doors is using the deadbolt when driving because it doesn’t allow the door to move with the trailer. So door lock always, deadbolt only when parked and leaving to adventure your location or sleeping at night.
I know this is probably not the issue with your trailer but thought it was good info to pass on.
10-02-2020, 02:18 AM
#31
2016 25' Flying Cloud
z
You can unscrew the striker plate and tap it with a hammer, then tighten it back up, it does have some adjustment. That's how I did it,
10-02-2020, 04:57 AM
#32
2014 23' International
Hurst
This is complete nonsense. "Dealers" just tell stuff as fact without having any real understanding of what they are talking about.
10-02-2020, 07:24 AM
#33
Oswego
Originally Posted by ROBERT CROSS
I do the same thing exactly...except different.
Most of the time I don't use the front stab's at all. I find if the rear don't rock the front won't rock.
Ummm, doesn't that depend whether it is a front or rear bedroom????
-Rich-
10-02-2020, 07:35 AM
#34
CLOUDSPLITTER "Tahawus"
Zanadude Nebula
, Milky Way
YES...along with type & quantity of imbibed beverages.
10-02-2020, 07:44 AM
#35
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Exactly what we do. I require a lot less sleep than my lovely wife. I can close the door very quietly from the outside, but haven’t figured out a way to quietly close it from the inside. If I try an easy pull it ends up partially closed and I have to slam it again. So I make sure to give it plenty of force on the first attempt.
Multiple or repeated slams are not welcome by SWMBO..
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
10-02-2020, 07:52 AM
#36
Hurst
HERE is why your deadbolt isn't working: https://www.airforums.com/forums/f44...ir-194997.html
Now, once again, you know MORE than the "dealer."
10-02-2020, 04:29 PM
#37
Freedom
Dallas
, TX
Okay, I got my trailer back. They said that had to remove rivets in order to completely remove my dead bolt lock and tighten it up before reinstalling it. It appears they can loosen up and this is what cause my issue. Now, it is SO much easier to close. One simply slight push and it snaps into place and locks easier than before.
He told me it isn't something I would ever want to do myself because you really need to know what you are doing. It is easy to mess things up evidently.
Hopefully, this will be of some help to somebody.
11-10-2020, 03:18 PM
#38
1976 Argosy 26
Lake Wales
I pull the door handle out to close then let it lock in place. Slamming will break the system. If yours is the same as mine it is a bear to repair.
