Old 04-11-2021, 03:49 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Ď76 Argosy lock
My handle and lock are intact as you can see. However, when you pull the key out the entire tumbler (?) if thats what itís called can pull out.
Is this fixable, repairable or unobtainable?Click image for larger version
Dan
Dan S is offline   Reply With Quote
Old 04-12-2021, 09:02 AM   #2
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Dan, yes almost certainly fixable as your lock seems to be complete. I would remove the whole thing from the door, collect all the parts and bring them to the "oldest" locksmith you can find. 3-4 years back when I did my '76 Argosy a decent selection of parts were available, not sure now.
Good luck, Mark D
mrdes8 is offline   Reply With Quote
Old 04-17-2021, 02:16 PM   #3
Dan S's Avatar
1975 Argosy 26
Good luck, Mark D
Is it just these three screws that hold the lock and handle onto the door? Once screwed out from the inside, the entire assembly will release and can then be taken to the locksmith? Any thing to be worried about when pulling out like parts dropping to the bottom of the door ?
Thank youClick image for larger version
Old 04-18-2021, 03:32 PM   #4
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
So Dan, yeah, 3 screws - pretty simple, probably 1 or 2 coming in from the frame edge. Some sort of set screw holding the handle on. It's ok to drill out a few rivets right there around the handle, move the inner skin a bit to let the lock button slide by. Back of lock moves out from door and then slides back and out. There's usually wood or insulation right under the lock so parts that fall (most likely not) won't go far. It's been several years so I really can't remember what keeps the tumbler in place, clip? screw? It's usually pretty obvious. Take a pic. Even if its easy, have the lock gone through and extra keys made.
Mark D
Old 04-18-2021, 05:04 PM   #5
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
The brass clip in lock cylinder is broken or popped out. Locksmith can replace clip. Try removing cylinder first and see if clip is there. If not take only the cylinder. If you dont feel confortable, take the complete lock as other have suggested.
montanablue is offline   Reply With Quote
Old 04-18-2021, 08:24 PM   #6
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Glad montanablue chimed in, he's the man on locks....
Old 04-25-2021, 06:24 PM   #7
Dan S's Avatar
1975 Argosy 26
If I understand you, the cylinder (where key goes in) I can pull it all the way out? Iíve been Leary to do so as I donít want to make a bad situation worse. If there is no clip attached, take it to a locksmith and they can probably install one. Once that happens, do I just reinstall the cylinder and Iím good to go? Thanks guys.
Dan
Deadbolt Lock - will not lock due to pin strike point PSU1981 Doors & Locks 20 03-11-2021 04:37 PM
Canít lock KT lock from inside Madmarke007 Doors & Locks 1 07-25-2017 08:12 AM
Help - Deadbolt Lock won't lock PSU1981 Windows, Doors, Locks & Vents 1 11-21-2016 12:04 PM
Updated keyless entry lock BAUER LOCK sc17842 Doors & Locks 6 03-22-2016 09:53 PM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
