Old 02-09-2021, 12:05 PM   #1
1972 25' Tradewind
fort lauderdale , Florida
72 Tradeind Entry door hinge
I've attached a pic of my upper hinge which has 2 cracks(1 in hinge, 1 in the base plate). I assume I need to replace and it will be easier now that I have the interior gutted.
The interior bolt and nut side of the hinge are rusted and may take some work to get off. I'm wondering if I should attempt taking the lower one off also, to clean up the bolt side also, in case I have to get to it in the future.
My main question is, on Out of doors Mart and Inland RV (out of stock) the listing for this hinge says 1973-1992. They do not have a 1972 hinge.
BTW, this is cast aluminum (I think) and it couldn't be welded could it?
This is a 1972 Tradewind but the hinge looks exactly the same. Is there something I'm missing? Are they the same hinge?
Any other vendors I should try fro a replacement?
thank you
ID:	388366   Click image for larger version
ehodg66 is offline   Reply With Quote
Old 02-09-2021, 05:24 PM   #2
Paradise , Texas
It is the same hinge. If your trailer was produced as early as 07-1972, it could very well be an early 73. And sold before 1973 and titled as a 1972.
The 1973+ hinge will work fine. Replace both
Crackerman is offline   Reply With Quote
'67 Entry Door Hinge Pin Dingo Girl Doors & Locks 24 04-16-2020 12:03 PM
entry door hinge adjustment ggebheim Doors & Locks 2 11-02-2010 09:36 PM
<Shot in the dark> entry door hinge Benjo Doors & Locks 17 12-11-2008 09:26 AM
Entry door hinge TomW Doors & Locks 35 07-17-2008 07:04 AM
