Old 12-02-2019, 06:15 AM   #21
1981 31' Excella II
New Market , Alabama
There are tons of these modern door locks out there. You could probably adapt something like this. These are really common on modern RV's so you are likely to find parts. You can get them in just about any finish you want. What you got to lose for $25. There is probably a manual somewhere online but I would just buy one and see what the measurements are going to be by playing with it. Hopefully you can use the same hole and enlarge it a little. If not, then make a patch and mount the lock where it need to go.
https://www.amazon.com/Travel-Traile...5292254&sr=8-6
Perry
Originally Posted by Happyjoemay View Post
Perry, Your suggestion is likely going to be the answer to my existing door locking situation. I was encouraged by NavyCorpsMan's luck at VTS but apparently VTS has exhausted their supply of the parts in question. Do you have any thoughts on a source for any of the measurements or specifications of the innards of the locking cylinder?
Thanks!
Joe May
Old 12-03-2019, 07:18 AM   #22
1972 31' Sovereign
Edmond , Oklahoma
Perry, thanks for the scoop. I'm going to try it. Ill let you guys know how it goes. I'll save my Keeler stuff in the event I ever find what's needed to make it work but if I can make one of these work (and I will) it will give me some peace of mind. I worry every time I leave.
Happyjoemay is offline   Reply With Quote
Old 01-11-2020, 08:00 PM   #23
Dripping springs , Texas
I believe you need the KT Lock for a '72. They're for '70 - '77.
Keeler is from '78 to '90 (?)
I know because I've spent several hours looking for KT Lock parts online for my '75 Overlander. I cannot find them anywhere.
Jpmike23 is offline   Reply With Quote
Old 01-12-2020, 06:52 AM   #24
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Vintage Trailer Supply and Out of Doors Mart carries parts for the KT. That's where I get mine.
cole3444 is offline   Reply With Quote
Old 01-12-2020, 08:22 AM   #25
Yes they do...sorry, I should've been more specific. I believe the specific part I'm going to need is a new cylinder and those don't seem to be available anywhere at the moment.
sovereign
need asap 1975 argosy door lock and handle etc Gosman Doors & Locks 3 06-14-2010 06:00 PM
Bargman L-77 Door Handle Lock Assembly Bob Parker Doors & Locks 7 05-06-2010 04:41 PM
Argosy Main Door latch/lock/handle problem jjustice Doors & Locks 0 12-30-2009 10:45 AM
Found....new Bargman door handle/lock for many '50s to '60s Rog0525 Doors & Locks 45 10-31-2009 12:05 AM
Inner door lock handle ve3czn Doors & Locks 1 09-15-2007 10:37 AM
