Old 05-27-2024, 04:38 PM   #1
1965 17' Caravel
Opelousas , Louisiana
65 Caravel Door Replacement
Howdy.
I have been looking high and low to find a replacement door and hinge for my 65 Caravel. No luck so far.
I did find a 66 Land Yacht, but waiting on the seller to give measurements.
Does anyone know what years could be interchangable for doors?
I have tried several places without sucess on locating a replacement.
Any advice or resources welcome.
Thanks ahead of time.
K
rambler1970 is offline   Reply With Quote
Old 05-27-2024, 05:28 PM   #2
19 Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Have you checked with these folks in Texas?
https://www.apvintagetrailerworks.com/
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 05-28-2024, 05:10 PM   #3
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
Doors are tough to find but occasionally they surface. Consider saving the old one and reskinning it. The frame can be reused if it's not badly damaged.
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 05-28-2024, 06:14 PM   #4
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Airstream used cast aluminum door frames through about 1972. I don't know how extensive the damage is to your door, but there are folks out there that can "rebuild" the cast door frame to fit your trailer. They make a wood template of the curvature of the door to the body, and then cut and weld the frame to that original shape. Once done, they you can reskin the door both inside and out and maybe install a better lock set as well as a dead bolt. Big project, but might get you on the road quicker.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 05-28-2024, 06:31 PM   #5
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
Colin Hyde used to fix doors. Might be worth a try to contact him. Colin spoke about it on his Podcast- the VAP. I think the door can be shipped.
#Vintage Airstream Podcast #
Dingo Girl is offline   Reply With Quote
caravel
Main door lock replacement? DIY? 1967 Caravel Caddyshack 1966-68 Caravel 6 07-05-2019 08:27 AM
Replacement Keys for Entry Door/Water Input door? Marlin4622 General Repair Forum 4 09-22-2018 07:11 AM
Pre-war Door Hinge (Door-in-door) ekstarr Doors & Locks 0 06-26-2018 02:37 PM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
