Old 06-19-2021, 03:46 PM   #1
1988 29' Excella
Austin , TX
WeBoost Antenna Switch
Hopefully this is an easy question. I am installing a WeBoost Destination RV which includes a directional antenna (314445). I also bought a Omni-directional antenna (304423). My plan is to permanently install the omni-directional antenna on the roof. The direction antenna would only be used when the omni-directional antenna does not provide sufficient reception. Thus, I would not need to bring out the 25' pole and setup the directional antenna unless necessary. What I want to be able to do is install a switch to toggle between the permanently installed omni-directional antenna and the directional antenna when it is being used.
My question is what antenna switch do I need to use? Will any coax antenna switch work or is there unique specifications for the WeBoost that I should be aware of? Has anyone else done the same thing and have a suggestion?
TIA!!!
John
JohnnyAustin is offline   Reply With Quote
Old 06-20-2021, 07:33 PM   #2
SandKSmith's Avatar
Scottsdale , Arizona
I thought about doing the same thing, then just put up the directional antenna. Itís less work for better performance . I use the OpenSignal app for aiming it. The gain is worth It.
Steve
SandKSmith is offline   Reply With Quote
Old 06-21-2021, 01:41 PM   #3
1988 29' Excella
Austin , TX
Yes, well it looks like you have a crank up antenna. The one on my trailer had been removed or that's exactly what I would do. Regardless, I do appreciate your response.
WeBoost Roof Antenna dougtuck Working on the Road 21 02-02-2020 09:40 AM
Weboost external antenna The Colonel Phone, CB & Ham Radio 24 07-27-2019 08:59 AM
Weboost Interior Antenna Daquenzer Electronics & Connectivity 1 10-03-2017 01:27 PM
Weboost external antenna The Colonel Computers, Internet & Satellite 15 11-02-2016 09:50 AM
Verizon Jetpack external antenna vs. Weboost? DarrellT Computers, Internet & Satellite 13 09-07-2016 06:08 PM
