RFI from Progressive Dynamics charger/converter
I replaced the Airstream OEM converter/charger ("univolt") in my 2007 34SO with a Progressive Dynamics PD9260 tri-mode unit. It works great and I'm getting 5 yr.+ life on the Optima AGM batteries. The problem is the RF hash on the 40M & 20M bands that comes from the unit. I'm using a Yaesu FT-847 transceiver with their ATAS-100 mobile antenna mounted on the trailer roof. When I unplug the converter, the RFI disappears so I'm sure that's where it's coming from. Emails to Progressive Dynamics technical support have not been effective with the last reply suggesting putting different value capacitors across the output to see if the RFI is reduced or eliminated. Anyone else have this same experience and what have you done that worked?
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
