Old 02-06-2020, 10:33 AM   #1
2018 16' Sport
Gig Harbor , Washington
How to mount WeBoost 65 RV antenna pole
We purchased a WeBoost 65 RV cell phone booster. The booster works fine but because of the curved sides on the airstream the pole supports pre-attached too the antenna pole won't work with the brackets intended to work with the supports.
Any ideas on how to best provide the necessary pole support in this situation? Me standing outside and holding it doesn't seem like a great solution 😜
Thank you for any ideas.
rossdn is offline   Reply With Quote
Old 02-06-2020, 10:50 AM   #2
1981 31' Excella II
New Market , Alabama
My first thought is a suction cup rig with an outrigger. Awning brackets might be another attach point.
Perry
Old 02-06-2020, 01:42 PM   #3
2020 Classic 33
Box Elder , South Dakota
Something like this. http://www.uncommonflagpoles.com/alu...drv-stand.html I’ve got this one from when I had my motorhome works well for either the pole that came with the RV65 or a regular flag pole. I generally use the RV65 pole and put a pulley on the top so that I run up a flag.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 02-06-2020, 07:10 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
2x this plus using 1/2 inch electrical piping (inside 1 inch electrical piping if you want more height).
Originally Posted by ghaynes755 View Post
Something like this. https://www.uncommonflagpoles.com/al...drv-stand.html Ive got this one from when I had my motorhome works well for either the pole that came with the RV65 or a regular flag pole. I generally use the RV65 pole and put a pulley on the top so that I run up a flag.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 02-07-2020, 06:24 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
I made a mast out of black abs pipe from the big box store. I glued screw on fittings so that the mast can be taken apart into smaller pieces for storage. The mast, when put together, is 13 feet tall. The bottom of the mast slips over a flag pole holder that is held in place on the ground under the tongue jack. The wire for the booster is run up through the mast and comes out on top in a hole I drilled into the side. It works well.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 02-07-2020, 08:13 AM   #6
Boerne , Texas
Images: 18
I was going to set up one of Weboost's wall mounts above the midline before it starts to curve and put the bottom into a flagpole mount like what ghaynes755 suggested. The problem is that they probably need an absolute vertical mount to slip in properly so what if you found a T shaped piece of material and mount that to the wall mount, then mount the pole to the end of the T using a round band to wrap around the pole and attach so that it could pivot on the end of the T. Now, if you can build your own flag pole mount that would be even better because the cost looks unreasonable for what they are...
Now to control longitudinal strain I'd think of some stays at angles away from the pole to a spot on the side to help reduce the twist on the wall mount in high winds. I was thinking of putting mine between the fore and aft awnings on the street side and use the awning mounts to help stabilize it. I'd run the wire in through the lower refrigerator opening and to where ever you have the receiver.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 02-07-2020, 08:24 AM   #7
Mollysdad's Avatar
I like painter's poles. Not the cheap twist lock, but the button lock.
They last forever, go up about 15', and the top fitting can be MacGyvered into an antenna mount.
If you want taller, and spendy, look into Hastings "Hot Sticks". They're designed for electrical workers to shut breakers on transformers.
Fiberglass, button lock. Various lengths. (Telepole II)
ID:	360671   Click image for larger version
Old 02-07-2020, 08:35 AM   #8
turk123's Avatar
2019 30' Classic
Canfield , Ohio
Here is a thread on what I built. Read to the end to see the final solution. It works very well and is simple to make and setup. No holes were drilled when making this movie!
https://www.airforums.com/forums/f45...ct-156121.html
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 02-07-2020, 09:19 AM   #9
2018 27' Flying Cloud
Atlanta , Georgia
I tried to use the two plastic stick-on pole supports but because of the curved surface, the upper one delaminated.
Instead I use a luggage strap to tie the pole to the (retracted) awning support on the driver's side near the front of the trailer. I still use the lower plastic support but the strain of the wind goes almost entirely to the strap. I have a FB trailer so the booster is located in the cabinet where the DVD player is located at the rear of the trailer. I use the satellite connections on the driver's side of the trailer to connect the antenna cable to the booster inside. The satellite cable comes out in the same rear cabinet.
It is also important to secure the base of the pole with tent stakes.
jnm30327 is offline   Reply With Quote
Old 02-07-2020, 09:51 AM   #10
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
I've seen WBCCI A-frame flag mounts used for this purpose.
I don't have flags so I would probably fabricate a tube to bolt/clamp to the A-frame and let the mast drop through to the ground.
BillfromWI is offline   Reply With Quote
Old 02-07-2020, 11:30 AM   #11
chugchug's Avatar
2018 25' International
Belmont , California
My solution is to use an omnidirectional antenna permanently attached on the roof with VHB tape and a simple aluminum bracket. The system is permanently wired and all I have to do to use it is to turn on the power switch.
The directional antenna that came with your kit will have a slight advantage but only when directed towards the cell tower. How to find the optimal direction is difficult. Otherwise, the omnidirectional is just as effective. I did try to use one, and only once was I ever able to get a better reception with the directional antenna. Otherwise, the omnidirectional did just as good and with much less fussing.
I think the antenna that came in your kit is 75 Ohm, so the 304421 is what you want
https://www.weboost.com/products/wil...antenna-75-ohm
chugchug is offline   Reply With Quote
Old 02-07-2020, 01:40 PM   #12
RonandLu
1999 30' Excella 1000
Payson , Arizona
Paint pole in this
I made a bracket from a paint roller handle and mounted the antenna on an extendable paint handle. This is what I made to stand it in. It is currently under a stabilizer foot and can be used under a tire also. I like the ability to place it anywhere on the campsite.
I have no idea why my picture stays inverted.
Name:	Base resized.jpg
ronandlu is offline   Reply With Quote
Old 02-07-2020, 03:42 PM   #13
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I was just asking this question and GMFL (Ronnie) sent me what he uses. He uses the ground pole mount along with a marine vacuum suction cup. The cup has a d-ring that you tie the mast off with. You openly need one. This thing ain’t going nowhere and its not permanent.
https://www.seasucker.com/collection...l-d-ring-black
Troutboy
Troutboy is offline   Reply With Quote
Old 02-07-2020, 04:26 PM   #14
2018 16' Sport
Thank you all for the great ideas, I should be able to come up with a great solution from these.
Old 02-07-2020, 04:29 PM   #15
2018 16' Sport
Do you have a picture? I like the sound of it.
Old 02-07-2020, 05:08 PM   #16
2020 27' Flying Cloud
I have used this for a couple of trips:
https://www.technorv.com/suction-cup-antenna-mount-1/
I am not sure this is the best solution as the vacuum is not adjustable. Although you cannot see it, I can rub my hand across the area where the techorv suction cup was mounted and it is slightly raised.
I am not sure what the long term effect will be and would be interested in opinions as to whether i should find another option. I would not like to have a big wart on the side of our new Sheppie Shak.
Brainodo is offline   Reply With Quote
Old 02-07-2020, 09:50 PM   #17
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
If you plan on attaching your pole to a roadside or rear awning arm, you may want to consider replacing the arm to bracket bolt with a 1/4 stainless eyebolt to provide an attachment point.
Note, the arm is under tension at the awning. To keep it from violently flipping up, you will need to simultaneously insert the eyebolt while removing the bolt.
Greg
greghoro is offline   Reply With Quote
Old 02-08-2020, 08:04 AM   #18
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I want to thank Turk123 for the link to Metalsdepot in his thread. I use a different solution: I put a deck brush extension pole into a piece of PVC pipe hose-clamped to my WD jack. But, I am changing to a heavier antenna and I am not certain whether the pole is strong enough. Metals Depot sells all kinds of metal tubes, including a thick wall aluminum tube perfect for my needs. The people on this forum find some great resoources...thank you.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-08-2020, 12:10 PM   #19
PSU1981
PSU1981's Avatar
2015 27' Flying Cloud
Conroe , Texas
Yep - use 2 of these - locks on solid - works great
Glenn
PSU1981 is offline   Reply With Quote
Old 02-12-2020, 11:14 AM   #20
Ed rottinger's Avatar
2005 16' Safari
2006 25' Safari SS SE
1996 30' Excella
Iron River , Michigan
Mounting for Weboost
I purchased a stainless steel handle from West Marine. Then mounted it to the refrigerator vent and the antenna to that.
Ed rottinger is offline   Reply With Quote
WeBoost Drive 4GX RV pole antenna dream TBone55 2016 - Current International 23 06-11-2019 08:43 PM
Rooftop Antenna (Screwless) Mount - Wifi Ranger and WeBoost godber Computers, Internet & Satellite 17 12-02-2018 10:59 AM
flag pole mounting and flag pole in general chrischarles General Repair Forum 42 08-09-2017 02:05 PM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 12:52 PM
