Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 08-07-2009, 11:16 PM   #1
cclarkego's Avatar
1966 24' Tradewind
Oak View , California
Images: 8
Why does my wireless come and go?
I just moved my trailer home into the backyard. I have a wireless router in the house which works just fine with my laptop on the patio ten feet away from my trailer. Inside the trailer though, it fluctuates up and down all the time. I am staying in the trailer nearly fulltime right now and want to use the computer in there. It is driving me batty.......
Why is this?
Carol
cclarkego is offline   Reply With Quote
Old 08-08-2009, 12:07 AM   #2
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
I have the same issue. Am curious what replies have to say. Some say it's the metal exterior, but if that were the issue then why at some campgrounds can I get good reception inside the AS? But not at home.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
https://www.airforums.com/forums/blog...-maryw164.html
https://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 08-08-2009, 05:37 AM   #3
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Pure conjecture here. I'd guess it has to do with the orientation of the trailer to the router. The trailer, because of it's all-metal design, will act as shielding... except that it has windows that don't. If the trailer is situated where it has line-of-sight through a window to the router, and the computer is near the window, you'll probably have great signal. Otherwise, you'll get what drifts in and bounces around.
Again... pure conjecture. If there's a propeller-head out there who really knows, and I'm wrong... please straighten me out too!
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
85MH325 is online now   Reply With Quote
Old 08-08-2009, 06:09 AM   #4
1998 28' Excella
Dolores , Colorado
We have just gone to wireless and for the most part don't have any problem with the router. We have found that with most electrical items (Serrius, etc) you need an antenna that is oriented towards a window for better reception. One of our unit members has the vintage motorhome and hehas said he needs an antenna to his router to get better reception.
Whether or not this is conjecture or not that is the way it works with an A/S.
Good Luck with your system.
4CU/CAC
AIR 28748
dogpound is offline   Reply With Quote
Old 08-08-2009, 06:13 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Wireless is line of sight. I have had a fellow Airstreamer or two stay at my place and they could get wireless depending on how they were parked. The aluminum does shield the signal and I am sure causes it to bounce around quite a bit. We have multiple routers and signal amplifiers at our place and get interesting results sometimes.
Aaron
WBCCI #XXXX AIR #2495
Old 08-08-2009, 07:12 AM   #6
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Try re-orienting your antenna(s) on the router, may help. anyone really working in IT will tell you that whole 300' range is so iffy it's not funny. Everything from sunspots to gopher holes can effect your signal. A wire in the wall of the trailer or house.. the angle of your gutters.. the tag on your dog when it lies between you and the router..
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 08-08-2009, 07:28 AM   #7
Retired.
. , At Large
We had this problem while fulltiming, and got this thingamabob:
Linksys by Cisco Wireless-G Range Expander WRE54G
I put it by the door of the trailer (outside, just under the edge of the bellypan), and we had no more connectivity problems.
The aluminum shell of the trailer acts as a Faraday cage, and blocks radio signals, especially weaker ones.
Old 08-08-2009, 07:44 AM   #8
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I have often wondered the same thing. Most of the replies I read here wouild adress a situation where you just have a bad signal due to distance, shielding, etc.
But my problem, and I'm guessing this is what the original post might have referred to, is that one minute the signal can be very strong, five bars out of five next minute fades to almost nothing, maybe one bar on the scale. And this without anything physically changing that I am aware of.
I wouldn't think it woud make any difference how many people were using the signal, I would think that might only affect the download speed.
All very strange!
Brian (Camped at Penn Wood Pa, where I am experienceing exactly this wifi phenomenon! Generally an excellent wifi setup though!)
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 08-08-2009, 07:57 AM   #9
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
All very strange!
Again, Brian... I'd conjecture that most of what you're getting is reflected signal off the inside of the trailer, and these signals are really at the mercy of the whims of the atmosphere and environment.
Roger
Old 08-08-2009, 08:01 AM   #10
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
My signal varies also, depending on the position of the trailer in my yard. Terry's thingamabob is probably the best solution, but if your wireless adapter allows for an external antenna, you may want to try one. If so, a directional one would be best. Such as:
WiFi Antennas-Super Cantenna Wireless Booster Antenna
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 08-08-2009, 08:06 AM   #11
Retired.
. , At Large
Is that an antenna, or a grenade launcher?
Seriously, if you have a USB wifi antenna, you can get a 10 foot USB extension cord, and place the antenna up in the roof vent, where it will be higher and have less interference. It's also cheaper than the booster.
Old 08-08-2009, 08:44 AM   #12
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Signal strength fluctuations are probably caused by the wireless router. I would try moving the router or replacing it.
When we are on the road we use a Wave RV external Wifi unit to bring in distant signals. Many times this is the only way that we can get on line at a campground without taking our notebook up to the office.
The Wave RV is an external Wifi card with a small antenna. We are very satisfied with its operation, and we have been using it consistently for about two years now. We are about to buy a second one as a back up and to allow both of us to be on-line simultaneously. Since we run our internet business while traveling in Lucy, this would be advantageous for our situation.
You can find these units at RadioLabs - Radio, Wireless and Beyond -. They are somewhat pricey at $130, but have come down considerably since we bought our two years ago for $220. These units are hand assembled by a small company in California. We have absolutely no association with Radio Labs. We have just been pleased with their product and want to pass it along.
When necessary, we mouint our Wave RV to the top of 22' flag pole in a plastic bag and connect it using a USB extension cord.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 08-11-2009, 01:10 AM   #13
cclarkego's Avatar
1966 24' Tradewind
Images: 8
Bandwidth a Health Hazard?
All very strange
Strange, yes indeed....and mine is doing the exact same thing as quoted above. Up, down, up, down. I have to always look before I click!
Unfortunately, my router is at the other end of the house, I at least tried moving up high on top of a bookshelf which did help somewhat until I can try out some of those gizmos.
What is totally weird is when I do click, I see the bands drop down, as though my click really is sucking up some of the bandwidth.
Maybe it is something to do with how many people are using the signal. I know the cable guy once told me when I was getting dropped all the time (not on wireless yet) that with all the increasing customers, the lines needed to be beefed up. I told them they better beef up the cable near my house pretty darn quick, then called them out every single day until they did. I didn't get dropped anymore.
If this is the case, what are they going to do, thicken the air? Pretty soon we will be able to actually see bandwidth, like a haze. Next we will have bandwidth pollution and it will have a name like smogwidth. We could have sooty little thoughts and pictures dropping all over us. The audio portion alone will cause a new stress related syndrome and the pharmaceutical companies will have to come up with a new drug for it.
On and on it goes........
Carol
Old 08-12-2009, 12:20 AM   #14
norsea's Avatar
2008 30' Classic
On the road since 2000 , norseaodyssey.com
Brian
The problems that computer users in RV parks and the RV park operators face are so intertwined that it is difficult to discuss one without giving due consideration to the other.
For example, for the RV park owner offering wifi service has become almost as expected as having cable TV, electrical connections, water and sewage disposal.
What has been discussed in this thread as of this posting falls into two categories:
1. Wifi signal strength.
2. Park network speed and/or ability to handle large volumes of data traffic when the park wfi network is busy.
As a general rule an RV park will have a single ADSL (DSL) line that is the connection between the network in their park and the internet. DSL was never intended to provide throughput for large volumes of data. It was intended to provide throughput for a few computers in a household or small business.
For large volumes of data the telephone companies have traditionally offered fixed data rate data service for business use. The cost differences between DSL service which is generally less than $100 a month and a data line for large volumes of data is astronomical.
So, the RV park operator has someone come out and install a router with a DSL line for the internet connection. His customers complain that they cannot get a signal for the wifi in their trailer so he has the installer come back and they install and exterior antenna for the router.
This helps people in the immediate range of the antenna but for most parks a good portion of the campers do not get the signal.
So the installer is summoned once again and a site survey is performed and multiple routers/repeaters are installed in different locations throughout the park each with an external antenna. Each of these repeaters is fed back to the main router in the park that has the connection to the internet.
All a repeater generally does is repeat the signal that the single router with the internet connection broadcasts; the repeater can also provide a network (IP) address to the computers connecting to it.
Now everyone in the park can receive the wifi signal. Wooo hooo!!!
But, when you use your computer the response is so slow you give up and put it away.
You complain to the RV park operator. For the park operator wifi has become a nuisance.
The only solution for this is more DSL lines and/or a legitimate data link with the bandwidth capable of supporting all of the computers that could be on the network at any one time.
Most RV park operators are reaching the point that they would like to see wifi go away. They do not have the technical expertise to administer the systems and the people that do so charge large amounts of money for their services not to mention the fixed costs for the hardware, the installation and the recurring monthly charges paid to the telephone company for the internet connection.
So, given that most park operators do NOT have the installer come back and do a site survey, or bother to do one in the beginning as should be done, because they just don't want to spend the money, it is easy to understand why we campers suffer weak wifi signals in our camp space; the wifi networks in most parks are grossly undersized in both areas of concern:
1. Insufficient repeaters/antennas to cover the facility adequately
2. Insufficient bandwidth for the data connection to the internet for the volume of users on the network.
As a user there is nothing we can do about the second item, the bandwidth of the connection to the internet that the park has purchased from their network provider.
But we can do something about the signal strength that we receive in our aluminum trailers/motor-homes.
As was pointed out in one of the posts in this thread, wifi signals travel in a straight line, and weak radio signals do not pass through metal. As a result, any object that is between the point of origin of the wifi signal and the receiver will impair the quality of the signal. The weaker the signal being broadcast, the more susceptible it is to signal degradation. Given that wifi signals are broadcast at a very weak level as dictated by federal regulations wifi signals can easily be impaired.
Through my own testing I have determined that the vast majority of wifi signals that I am able to receive when inside my Airstream are reflected signals. That is, the are not coming into my trailer directly from the antenna that is broadcasting them, but they are being reflected (bounced) by another object, be it another RV, a building, a tree, etc., etc.
Over the course of the past two years that we have been traveling full time in our 30' Classic I have approached the weak wifi signal issue with multiple solutions.
As was pointed out by Brian, above, Radio Labs is an excellent vendor for wifi solutions. I find their staff to be knowledgeable and the products on offer to be of good quality and they do stand behind their products.
But, I have found another vendor that I believe has a better solution to the problem. That vendor is Jefa Tech Wireless Technology Solutions.
I have tried just about everything that has been mentioned in this post and other posts on this forum in an attempt to bring wifi signals into our trailer. I found the information on rv.net related to this subject to be invaluable. And there is a very good thread on the subject on the Escapess forum.
It was not until free firmware was developed that could be installed on various vendors hardware in place of the firmware that the vendors shipped was the solution I craved at hand.
What I needed was the ability to have an external antenna that was capable of picking up weak wifi signals and then repeating the signal inside our trailer with the repeater obtaining a network (IP) address using DHCP.
This way we could use the wifi built into out computers and not need additional wifi cards or usb solutions that had us tethered to something which, in our opinion, negated the whole reason for the wifi - for the computer to not have wires connected to it for a network connections.
We found that none of the solutions that Radio Labs offered could do this. And we tried many that they had simply because that was all that was available at the time.
But, with the advent of dd-wrt firmware that could replace the firmware that shipped with various vendors routers it is now possible to reconfigure a router so that it can not only operate as a repeater but that it can do so using DHCP for obtaining its network (IP) address; a fixed IP address was no longer needed for a router to be configured as a repeater.
This means that my router reconfigured as a repeater is capable of getting its address from the router in the RV park. If the RV park network is password protected the router can easily be configured to use the password and get connected.
We each can connect our two computers to our router configured as a repeater in our trailer and it passes us through to the network. As far as the RV park router is concerned there is one device making the connection and it sees only the MAC address for our router/repeater.
If the park has a web page that must be accessed and user id and/or password entered it will appear in our browser the same as if we were connecting directly to the RV park network.
The even better news for us if the park is charging a fee for access is that we only pay the fee once, for the MAC address for our router/repeater. Any number of computers connected to our repeater can then access the neetwork.
This is NOT something that any RV park operator who is charging for network access will be happy about and I have seen a few web pages pop up for RV parks that have discovered people who have been operating their router/repeater without passwords being needed to gain access through it to the network. They state that they will evict anyone so doing from their facility. Seems fair given that they are charging for a service and I suspect that doing this would be considered fraud; but lets not discuss that issue here please.
In order to gain access to our router/repeater you must have the user-id and password. This means our router/repeater is secure whereas the ones operating in the above example had no user-id or password and anyone receiving the signal could connect through it to the network.
In the initial stages of dd-wrt firmware availability it was strictly a DIY project for replacing the firmware on your router with the dd-wrt firmware.
But, now Jefa Tech is offering a turn key package of a Lynksis router with the dd-wrt firmware installed and configured for use as a repeater, with cable and external antenna and documentation. This can be found at their web site:
JEFA Tech Long Range WiFi Repeater Kit for RV's
I have tested their offering and it works as advertised. Call them on the phone to order and be sure to tell them you want it configured as a repeater.
For my antenna pole I purchased a telescoping boat hook from West Marine and removed the rubber grip and the hook. This left me with a three section telescoping aluminum pole.
I mounted the antenna to a piece of PVC that has the same inside diameter as the outside diameter of the smallest section of the boat hook pole with a cap on the PVC, for what I hope are obvious reasons.
I raise the antenna as high up as needed to give me line of sight between my antenna and the RV park antenna. This often times means higher than the 14 foot high motor homes and/or 5th wheels parked adjacent to us.
The pole slips nicely into either a flag pole holder or a piece of PVC with an inside diameter that matches the outside diameter of the largest segment of the boat hook pole attached to the trailer jack.
I hope this post will help others have a better understanding of the issues of wifi in RV parks and offer a solution that I find works much better than any others available at this time.
As always, YMMV.
Jim, who has no interest in or connection to either Radio Labs or Jefa Tech other than as a satisfied customer.
We are travelers with an attitude. We get to go anywhere, anytime, and have attitudes about what we see and hear.
"Travel is fatal to bigotry, prejudice and being narrow minded."
norsea is offline   Reply With Quote
Old 08-12-2009, 01:06 AM   #15
c177tx's Avatar
2008 19' Bambi
Images: 20
Norsea, very good post, I also went with a linksys wrt54gl and the dd-wrt firmware, I had trouble converting the gl into a repeater but did boost the power so now I have no problem getting the signal all over the property and into the airstream, that I am full timming in now.
c177tx is offline   Reply With Quote
Old 08-12-2009, 01:27 AM   #16
Maryw164's Avatar
1972 31' Sovereign
Jim,
That was a great post. I had already found that same website in my own research, but had not yet bit the bullet and made a purchase. Good to know I am on the right track. Your insight has been very much appreciated.
Mary
Happy Trailering !
Old 06-10-2012, 01:07 PM   #17
Looking for Adventure
KrazyKelleys's Avatar
1975 29' Ambassador
2020 25' Globetrotter
Social Circle , Georgia
Placement of Repeater
Hello Jim,
I am looking at doing the same setup you have. The question is where did you mount the repeater and does it need a 110 power source? If the repeater needs to enter the coach from the front could it sit underneath the sofa or does it need to be up higher? Please let me know and pictures would be even better. Since this thread is nearly 3 years old , please let me know if you have updated your setup for something even better.
David
As always, YMMV.
KrazyKelleys is offline   Reply With Quote
Old 06-10-2012, 02:13 PM   #18
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
You might want to look at WiFiRanger? They are set up for Airstreams.
http://www.airforums.com/forums/f451...ght=wifiranger
I have a modified mount on the Clipper that works great.
http://www.airforums.com/forums/f313...ml#post1144517
Dave
Originally Posted by KrazyKelleys View Post
Hello Jim,
David
Old 06-02-2013, 07:27 PM   #19
tfbeitz's Avatar
1979 31' Excella 500
1973 25' Tradewind
Cinnaminson , New Jersey
Thank you Norsea. Best article that I have found after looking all weekend.
Tom Beitz
6760 PA Unit
TAC NJ-5
Riverton, NJ
tfbeitz is offline   Reply With Quote
Old 06-03-2013, 07:12 AM   #20
Wireless signals don't pass through metal (like the shell of your Airstream) very well.
After annoying wifi troubles, I purchased a range extender from Best Buy. I put the extender outside the trailer near a window or skylight so it can beam the signal to my computer. End of problems.
handn is offline   Reply With Quote
Wireless Threats jcanavera Off Topic Forum 10 06-02-2005 07:33 AM
Wireless internet? krowsea Electrical - Systems, Generators, Batteries & Solar 9 08-20-2004 10:17 AM
Wireless Detector jcanavera Off Topic Forum 0 12-12-2003 09:23 AM
wireless internet lmbando Electrical - Systems, Generators, Batteries & Solar 10 11-06-2003 11:10 AM
Wireless Web Reception niftypkg General Interior Topics 1 11-08-2002 08:03 PM
