Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Computers, Internet & Satellite
Old 11-15-2015, 04:26 PM   #1
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Repurpose AM/FM Antenna for Cell Booster?
I've ripped out my Sony AM/FM/DVD head out of the dinette overhead cabinet. It will not be replaced as I've decided to upgrade the current TV to a 28" LED with DVD with audio coming from a Bluetooth speaker. The AM/FM antenna on my 25fb is located just behind the rear Fantastic Fan and its cable runs down into the cabinet area.
For internet on the road we seem to use cellular data more than Wifi. We don't normally stay in RV parks with Wifi nor park outside Starbucks, McDonalds to use Wifi. Right now I just create a Wifi hotspot on my iPhone to use my Macbook Air and iPads. Maybe eventually will add a Jetpack.
What I would like to do is is use a Verizon cell signal booster and take advantage of the location of the unused radio antenna for a 4g/3g antenna and use the existing hole to run cabling down into the dinette cabinet for the equipment. I'm hoping I can mount a antenna in the same spot I'm just starting to research this idea and it seems pretty confusing.
Kelvin
Old 11-15-2015, 04:54 PM   #2
Naples , Florida
Kelvin
Kelvin,
I install a good number of the WeBoost (Wilson) 5-band cell amplifiers. I'm pretty sure that the outside antenna port for these units is incompatible with a standard AM/FM radio antenna. I would also suspect that the cable properties like latent impedance would also be different.
These units come with a small magnetic antenna which we don't use; preferring the high gain units from Sure Call coupled with Wilson's ultra low loss cables. Have had great results with the above.
BTW; I always use the fridge vent to run the cables
lewster
Old 11-15-2015, 05:18 PM   #3
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Hey Kelvin, not going to work. Antenna's need to be matched to the frequencies they are going to work on. Ditto to what Lew says, I use a similar setup. For example, my directional antenna seen below is matched to work only on Verizon's band and won't work for sprint, AT&T or t-mobile. My Surecall omni works on a few more bands and works with sprint and at&t.
I went completely overkill and used LMR400 to wire mine to the booster. LMR200 would be fine.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-15-2015, 05:52 PM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
What about using the magnetic antenna that is supplied with the Weboost 4GX? I could mount a small metal plate on the roof and hopefully run the wire down to the dinette cabinet. Is it possible to fish the wire through or use the existing radio antenna wire to pull the booster's cell cable down? My Classic has the vinyl ceiling. I don't want to have it torn out to gain access.
If run cable down the fridge vent to you have to pull out the fridge?
Apparently, Weboost's new RV permanent antenna isn't ready for shipping until next year.
weBoost Announces RV 4G Cellular Booster, Drive 4G-X “Now Shipping” – RV Mobile Internet Resource Center
What about Surecall's product? Does it work as well as the Weboost?
All Carrier Mobile Cellular Booster-Vehicle Boosters-SureCall - Raise Your Bars
Kelvin
Old 11-15-2015, 06:04 PM   #5
Naples , Florida
The magnetic antenna will work, but you won't get nearly as much gain as using this unit: Outdoor Omni 3G/4G Antenna, 9.5 inches, 78 Reviews : 3Gstore.com
I pair the Sure Call antenna with Wilson's ultra low loss cable: 10' Black Ultra Low Loss Cable (N/Male Connectors) : 3Gstore.com along with a required adapter for a great package. The ULL cable is available in a variety of lengths too.
I also typically place the actual WeBoost unit either in the compartment above the fridge (if available) or in the space directly under the fridge. The inside antenna can be easily positioned on the fridge wall in either case and will provide excellent coverage from the entire front area of the trailer.
lewster
Old 11-15-2015, 06:34 PM   #6
Nomadic , USA
Those adapters that the 3gstore included can cause signal noise and degrade your performance, FYI. Had my cables custom made to length with matching ends from Ethernet Cable | Wifi Antenna Cable | AIR802 - also cheaper.
Although the average person probably isn't like me running speed tests and stuff. I do a lot of data pushes and want packet loss to be very low with low latency. So it's not like the adapters are bad, just not really preferred, IMO.
Old 11-15-2015, 07:46 PM   #7
Naples , Florida
Interesting! Thanks for the heads up! I'll definitely investigate them, as a few of my folks need higher data capacities as well. I was a bit suspicious of those adapters.
lewster
Old 11-16-2015, 08:18 AM   #8
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
So can one of these systems be a benefit when you are sitting outside the trailer or is the range on the internal antenna just inside the trailer.
Does the internal antenna have to be on an exposed wall or can I mount it behind a wood cabinet door?
Does anyone know how the external AM/FM radio antenna is mounted on an Airstream?. Does it have an internal nut that tightens up from inside the shell and is installed before the interior walls and insulation are put in place?
Kelvin
Old 11-16-2015, 08:28 AM   #9
Naples , Florida
Kelvin
Internal nut holds the radio antenna to the outer skin.
The inside antenna is a line of sight proximity device. You need to see it and IIRC be within 8-10' of it.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
Old 11-16-2015, 08:50 AM   #10
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
OK. So using the AM/FM antenna location is out of the question.
So if I want to attach an antenna to the TV antenna and run the cable down the fridge vent do I have to remove or move the fridge from the compartment to get the wires inside?
Kelvin
Old 11-16-2015, 08:59 AM   #11
Nomadic , USA
Kelvin
If going that route, yes. I tried, and just couldn't route them any other way.
My friend Shawn used a water proof grommet to route his into the overhead cabinet.
I'll qoute his blog for you here:
https://www.facebook.com/media/set/?...3552239&type=3
Instead of running through the refer vent like most people do, and since I wanted to keep all of my tech center in one location, I took quite a different approach. Using Heyco IP68/NEMA 6P cable glands, we were able to run the cables directly through the roof above the can lights. This makes the cable runs shorter and more accessible if a replacement needs to be made. I am happy to say that after raining for three straight day, in Las Vegas of all places, we are water tight! I'll have more of the tech center pics once I have everything in place.
Old 11-16-2015, 09:36 AM   #12
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
95.20 GB Used: I'm very jealous. That would cost me approximately one billion dollars in overages.
NWGetaways is offline   Reply With Quote
Old 11-16-2015, 09:50 AM   #13
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Man, nothing is easy about working on Airstreams. I don't have lights like that on my Classic. I have fluorescent fixtures along the center line. I have the Fanastic fan in the rear. Could a cable enter through that housing and be fished back to the rear dinette cabinets?
Checked out the Facebook photos. Are those wire retainers on the roof just stuck down on the roof with adhesive or caulk. Are they suitable for exterior use and won't degrade from exposure?
Kelvin
Old 11-16-2015, 01:35 PM   #14
gecko's Avatar
2009 28' International
Pacific Palisades , California
We actually use a Wilson Sleek--one in the Airstream and a separate one in the two vehicle. While not nearly as powerful or sophisticated as the units mentioned here, we do find it a huge help.
We mounted a steel plate and used the supplied magnetic antenna with the Wilson cables. For our 28' International, the cable routes to the area behind the sony head unit and then to the Wilson cradle. A major limitation is that the phone must be in the cradle to work.
gecko is offline   Reply With Quote
Old 11-16-2015, 02:06 PM   #15
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
How did you get the cable into the trailer? What size plate did you use had how did you attach the plate?
The antenna cable routing is the big issue with these units.
If I were to run a cable down the fridge vent, why can't you drill a hole in the wall between the fridge cabinet and the living room wall where the TV is mounted? There is a space between the fridge enclosure and TV wall deep enough to allow a 120v receptacle. Remove the receptacle and fish the antenna wire through.
Kelvin
Old 11-16-2015, 09:38 PM   #16
2007 25' Safari
Attleboro , Massachusetts
Thank you for this conversation. I camp a lot at Horseneck Beach and the internet is spotty at best so this is something I've been wanting to do.
romeb is offline   Reply With Quote
Old 11-17-2015, 05:44 AM   #17
2007 28' Classic
Ivanhoe , Virginia
We have used a Wilson Sleek for years at home with antenna on window bracket. We live just outside Verizon's service area and this brings the signal in enough for most of my internet requirements--better than our satellite. I can even stream video if I have a little extra data available!
horseylady is offline   Reply With Quote
Old 11-17-2015, 08:23 AM   #18
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Remember you will need a degree of separation between your external and internal antennas.
Another vote here fort eh surecall/wilson(we boost) set up. Works real well for me
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 11-17-2015, 08:42 AM   #19
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
If the antenna is on the TV antenna, which is cranked up over the TV/fridge common wall (25fb) and the internal antenna is attached to the TV/fridge common wall will I get the enhanced reception in the front bedroom if the internal antenna is pointed towards the back of the trailer?
Kelvin
Old 11-17-2015, 09:11 AM   #20
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Looking at the Weboost website the auto/RV solutions with the small flat internal antenna don't seem to be the best solutions as it only has a 3' range. The instructions from the Drive 4G-X states 36" range.
Is there a replacement indoor antenna that offers more range? If I have to sit in one area of the trailer within 3 foot of the indoor antenna that doesn't seem to be that useful.
Kelvin
Cell Phone Booster - Verizon pdozanne On The Road... 5 11-29-2012 07:37 PM
Cell Booster? gaylejoe Phone, CB & Ham Radio 5 05-14-2011 10:10 PM
Cell Phone Booster gaylejoe Phone, CB & Ham Radio 10 11-15-2007 12:19 PM
cell phone booster norbert Off Topic Forum 10 11-19-2005 07:41 PM
