03-01-2017, 08:44 AM
2016 30' International
Florence
, Alabama
Mast recommendations for exterior 4G antenna
I saw someone on here mention attaching a mast to a board that they put the front trailer jack on, and then routing the cables through the front where the battery cables go.
I'd like to do something similar but I'm having trouble finding a suitable mast. I was trying to find something that collapsed short enough to fit in the rear AS compartment, or the bed of my truck (short bed). I've seen a nice looking fiberglass mast that starts at 3'3" and goes up to 33'; but it got pretty bad reviews about it's ability to stay erect - it either collapses with temperature change, or breaks in half with a heavy gust.
I probably only need to get up to about 15', but the channel master metal telescoping mast is 9' long when collapsed.
03-01-2017, 11:01 AM
Tampa
Try a "hot stick". It's made for the power lines to trip breakers on transformers. Fiberglass, extendable, button lock.
Pricey, but just up your alley.
I used them in all kinds of weather, and they get bendy, but never broke.
I recommend the Telepole II. It's slightly triangular and therefore doesn't twist.
Hastings Tel-O-Pole II series of triangular shaped hotsticks with a 'no-twist' feature that enables each section to 'lock in automatically' with no need to search for the button.
Caution, use the flat of your thumb to push the button or it bites your finger!
03-02-2017, 08:43 PM
Florence
, Alabama
Thanks for the recommendation - and YIKES! those are expensive!
03-03-2017, 07:35 AM
2019 28' International
Going Where
, The Climate Suits Our Clothes
You might find something that fits your needs here https://www.mgs4u.com/fiberglass-push-up-mast.htm
I've been considering a similar set-up.
03-03-2017, 08:15 AM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
I have been using a collapsible aluminum pole used for paint rollers, etc. available at HD/Lowes. Affordable and lightweight.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
03-03-2017, 11:45 AM
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount
Take a look at www.flagpolebuddy.com. I've use one for a year and find it easy to use and sturdy. When I get to a PC I will find some photos of it deployed and some plates that allow you to hold it down by a tire, jack or mount. Search on my past posts if you need the info before I can repost.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
03-03-2017, 12:43 PM
2014 25' FB Eddie Bauer
Vero Beach
What about an extendable flag pole and a mount that goes under a tire on the trailer or truck? Here's a page with examples in different lengths:
https://www.baseballflagsandpennants...9159_prd1.html
03-03-2017, 03:07 PM
Rosemount
I went with the 16 foot (2" diameter) aluminum pole. It matches the Airstream, comes with a mount to our bike rack and is sturdy:
http://www.shop.flagpolebuddy.com/16...6016AL-Kit.htm
Here are some photos:
2018 F-250 6.2L Gas
03-06-2017, 05:43 PM
2015 25' Flying Cloud
Tappahannock
, Virginia
Built a bracket on the A frame to take a 1" square tube mast in two five foot sections.
See https://www.facebook.com/AirstreamTw...83436485072198
David & Margaret Broad
2015 25’ Flying Cloud
2015 RAM 2500 Laramie Cummins
WBCCI # 2381
03-14-2017, 01:08 PM
2017 23' International
Santa Monica
On another thread someone suggested a Tarheel Lift-and-Lay.
It's expensive but I'm considering it. Not terribly interested in climbing a ladder all the time to manually raise the antenna.
03-15-2017, 08:29 AM
2022 25' Flying Cloud
NCR
, Ontario
where do you pull the coax cable it?
03-15-2017, 02:01 PM
Florence
, Alabama
I've heard through the battery compartment. The you keep the extra spooled up on top of the batteries when not in use.
03-15-2017, 03:46 PM
Wise Elder
2010 30' Classic
South of the river
Josh,
Lots of choices depending on your budget, how much wind you expect it to tolerate, whether you will guy it, and how small is "collapsed," and how light is light.
Poles for tree pruners are very sturdy and will fit your truck bed. I have this one. I don't use it as a mast, I use it to prune trees, though:
http://www.homedepot.com/p/Jameson-H...4H4RoCD7fw_wcB
You can also use galvanized steel pipe, with couplings, in sizes that work for you.
Antenna places sell stuff that is supposed to be designed for the purpose:
03-15-2017, 05:21 PM
Florence
, Alabama
I mounted my trucker type external antenna to brackets I attached to the AC frame with a standoff and ran cable down through refrigerator vent. Probably not as good as what you are contemplating but no mast to deal with and on the road it has really helped.
The Colonel and Southern Belle
