Old 03-15-2021, 08:49 PM   #1
wildwoodrver's Avatar
2012 30' International
Pleasant Hill , The Golden State
Dish Tailgater failing?
Hi,
My 8 or 9 year old Tailgater is starting to give me grief. It will find satellites fine and then the next day will lose them. Also sometime it doesnít find all the expected sats so I donít have many stations. Most annoying is having to continually scan and set it up almost daily.
Dish has not been helpful on support, suggesting I eliminate all internal wiring in rig and hook it directly to the receiver.
Any troubleshooting ideas? I donít want to start replacing receiver and Tailgater if there is any remedy.
2012 International Serenity, 30
Reese Trunnion Weight Dist. Hitch
2005 GMC Yukon XL, Tekonsha P3
Reese Tow Beast hitch
Quadrasteer - Autoride
wildwoodrver is offline   Reply With Quote
Old 03-15-2021, 08:55 PM   #2
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Your LNB in the tailgater is probably going bad. It happens. 8-9 years is about right when they can start to present symptoms of degradation.
wulfraat is online now   Reply With Quote
Old 03-15-2021, 09:06 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have been using my tailgater for 6 years and no problems yet. I have heard if a gear that turns the dish failing and causing alignment issues. You can see the video here
Richard
Old 03-16-2021, 08:53 PM   #4
Thanks both. We moved today and got locked on easily. Weíll see if it lasts.
Iíll check out the video when I get a little beefier bandwidth and if it continues to act up.
Domestic Heat Pump Failing and failing and StanleyE General Repair Forum 0 02-07-2020 03:27 PM
Tailgater Satellite Dish-DISH TV Mrjkq Computers, Internet & Satellite 15 11-11-2016 11:18 AM
Any experiences with Tailgater Portable Satellite System by Dish? MarkMc Computers, Internet & Satellite 28 06-15-2013 09:16 AM
Dish Tailgater System with Airstream RichHog Audio, Video & TV 1 12-06-2012 05:39 AM
