Old 11-10-2023, 02:16 PM   #1
2024 25' Trade Wind
Boulder , Colorado
Connecting Starlink Antenna Cable to Airstream SmartPlug Ethernet
Has anyone tried connecting the standard Airstream antenna cable to the Smartplug Ethernet plug on a new Airstream?
Since this is a Cat-6 cable (I'm guessing at that), it would simplify getting the Starlink signal into the Unit.
Basically what I'm thinking is:
1) Cut the Starlink connector off the antenna cable and replace with an ethernet plug.
2) Where the Airstream Cat-6 cable Terminates in the media closet, connect
the POE ethernet cable from a Dishy or custom POE injector to the Inside Airstream Ethernet Plug.
3) Connect the POE device with a swapped RJ-45 Plug to a router inside the Airstream
I've been searching everywhere and can't find anyone who has done this. Is there something I'm missing that would prevent this from working?
Rich Howarth
richh is offline   Reply With Quote
Old 11-10-2023, 03:41 PM   #2
Keys Dave
2021 25' Flying Cloud
Big Torch Key , FL
I will be interested in your findings. Starlink has a proprietary system and who knows what might work. You might look at some starlink forums and see if they have any info. I'm planning on running the starlink cable through a 5" x 5" cable entry door I installed at the rear of my AS on the on the underside. It comes in inside the dinet seat. I can then rout the cable to the Starlink router and use their WiFi to send it throughout the AS , to the TV and laptops etc.
Keys Dave is offline   Reply With Quote
Old 11-10-2023, 06:53 PM   #3
2024 25' Trade Wind
Boulder , Colorado
The Starlink Antenna Cable is a standard Cat-6 Shielded cable (but with non-standard wire usage). In talking to people, the only reason I can see that the Airstream cable might not work is because it isn't shielded.
Rich
Pulling an Ethernet cable to outside of 2021 25’ FBQ Globetrotter jondrew55 Audio, Video & TV 6 11-13-2021 04:22 PM
Ethernet cable in wiring below blue ray player Kamerzel Audio, Video & TV 0 05-22-2021 11:15 AM
Blue Ethernet cable steilkurve Generators & Solar Power 4 11-01-2019 12:50 AM
Ethernet cable JKCA Electrical - Systems, Generators, Batteries & Solar 3 07-23-2014 01:09 AM
Ethernet, cable, internet for 09 airstream tmarquis Computers, Internet & Satellite 18 03-25-2009 07:59 AM
