Old 07-07-2021, 12:15 PM   #1
2016 25' Flying Cloud
tampa , Florida
Alternates to AT&T on Airstream Connect
We invested in Airstream Connect a couple of years ago and frankly are very disappointed with the signal speed we are getting with AT&T. We have travelled all over the West and Southeast and at best the signal and download speed is sub par. We end up using our Verizon hotspots and burning through our data. I'm told that it is possible to reconfigure for Verizon or other carriers. Looking for confirmation and advice. Will be discussing with Airstream when we return later this month.
fclewis is offline   Reply With Quote
Old 07-07-2021, 12:50 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
We get very good connect speeds from AT&T pretty much everywhere in the country. We don't use the Airstream Connect stuff, that (rather than AT&T may be the issue.
Old 07-07-2021, 12:56 PM   #3
Sag Harbor , New York
Maybe consider the new ATT Nighthawk hot spot?
https://www.airforums.com/forums/f45...-a-222129.html
. . . and drop the Airstream Connect entirely?
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 07-07-2021, 02:52 PM   #4
2014 25' FB Flying Cloud
Hillsborough , North Carolina
Could be "Carrier Aggregation"
Your problems with AT&T Connect might have more to do with the category of the modem in the router rather than AT&T.
Does your modem(i.e. router) support Band 14?
AT&T seems to be pushing quite a bit of data connections on band 14.
What category modem is in your router. It could be limiting the amount of carrier aggregation it supports. A good Carrier Aggregation connection is Well-Above-Par.
As Peter points out: the AT&T Nighthawk works great.
Are you still on the $360/year unlimited AT&T Plan? We have a few more months on that plan, but because it is on an older modem, we end sometimes not even turning on that modem, and instead use the 100G/$55 Nighthawk Modem.
Activating Verizon on an older modem will not necessarily get all that much better performance as compared to getting a newer modem. Pepwave sells several that have better modem and would be a fairly simple router upgrade in your Airstream connect.
Be careful sinking too much money into any router(i.e. Modem) these days. 5G is here and modems are quickly catching up........Equally and perhaps more important: Antenna are adding 5G support very quickly. Too much is changing right now to sink much money in a solution. It is changing too fast.
A near term solution is to buy the hotspots from AT&T, VzW & T-Mobile, and wait for the router vendors to catch up.
GeeSag is offline   Reply With Quote
Old 07-07-2021, 02:56 PM   #5
Thumbs up
Originally Posted by GeeSag View Post
. . . A near term solution is to buy the hotspots from AT&T . . .
Speaking of which . . . thanks for starting the following thread . . . our new Nighthawk hotspot has worked out great!
Peter
Old 07-07-2021, 06:44 PM   #6
Everyday is a GIFT !!
Nelson428's Avatar
2015 30' Classic
Collins , Mississippi
Send a message via AIM to Nelson428
I also use the AT&T plan with the Nighthawk and have not had any issues.
J. Nelson
TAC # MS-12
WBCCI # 5314
AirForums # 66116
Nelson428 is offline   Reply With Quote
Old 07-07-2021, 07:07 PM   #7
Did you disable WiFI as WAN?
fclewis:
Did you disable WIFI as WAN?
That would double your throughput potentially.
See Turk123's extensive thread on why disabling WiFi as WAN is so important on that router.
Old 07-07-2021, 11:02 PM   #8
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Starlink will be the game changer. EOY should allow for mobile use vs. fixed gel-location. 100MB download and very healthy upload is being reported. $100/mo.
There is simply no mobile LTE / cellular data plan offered today that comes close to what starlink offers from a speed and data usage perspective.
rvmobileinternet.com is your friend for researching all things data / internet for mobile / RV applications.
wulfraat is offline   Reply With Quote
Old 07-08-2021, 09:49 AM   #9
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Hillsboro , TX
Our AT&T history:
1. We had the AT&T Wireless Internet for $108/mo (including taxes) with a 100GB limit.
2. We switched to Airstream Connect in May 2019 and were able to renew for a second year; this ran out in May 2021.
3. We switched to the new AT&T Wireless Internet for $55/mo (prepaid plan) with a 100GB limit. We tried to use our old hotspot but had to spend $250 to purchase a new Nighthawk - as the old hotspot is no longer supported.
The new plan is working fine for us as we travel about the US.
Hope this helps!
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 07-08-2021, 09:49 AM   #10
2021 27' Globetrotter
Just researched using rvmobileinternet.com and got the Cricket (ATT network) $55 100g month plan. Worked great on a trip through Texas, NM and CO. The mobile hotspot device is a lot less expensive than the Netgear device. Don't buy from Netgear's website. They claim they provide free 2nd day shipping but sent mine by ground. It was too late for our trip. Now they won't refund. I went to Cricket and it was setup on the spot.
DutchB is offline   Reply With Quote
Old 07-08-2021, 09:55 AM   #11
Airstream Trippin
2020 33' Classic
Livingston , Texas
ATT Connect was only a marketing term used by Airstream to sell introductory data plans for ATT. The modem used by and in Airstreams is a pepwave that is housed in a cabinet in my Classic. You can use any modem you want to connect to cellular. ATT still doesn’t have the saturation coverage Verizon does on the West Coast but ATT does on the east coast. However, we use both ATT and Verizon for those times when one or the other doesn’t work. I would stay patient and wait for Starlink if you find cellular inadequate.
Gigler is offline   Reply With Quote
Propane Quick Connect Pieces & Parts Dallashayes Airstream Trailer Forums 0 11-18-2018 06:33 AM
1973 & 1976 Windows Parts & 80's Door-Negotiable tbashin Airstream Classifieds 0 01-01-2018 08:22 PM
Carefree Roadside & Rear Window Awning Arms & Rollers For 1976 31' Airstream Sovereign mrnos44 Airstream Classifieds 0 08-23-2016 07:08 PM
Goucho couch,original am/fm 8 track & lots of wood & aluminum from interior remodel gquailhunter Airstream Classifieds 0 09-19-2015 04:25 PM
