This has been an excellent thread for learning and catalyzing questions. Thank you all.
I checked with MIRC on a couple of the comments/questions. My question, and Cherie from MIRC's responses indented below.
Is the distance from electrical roof devices (AC or Fan) make sense?
12″ is the absolute minimum that Andy recommends.. .more is always better. And many manufacturers recommend 24″ as their minimum
Is mounting the antenna higher than the air conditioners going to improve performance as we move from site to site.
If you can install at least that afar away, then getting above the clutter is an option too. And height can help with getting a better signal, just avoid needing cable extensions to maximize the gain.
And, because we are trying to gain signal over miles, is there anything else we should be researching or considering in our mounting plan?
For further from a tower, that’s when panel and directional antennas have the advantage. We personally love the Akita because it’s a panel antenna but omni-directional so no aiming needed.
I have checked on the Akita. Many people use it as a back up if their roof mounted omni-directional is not gaining enough signal due to distance from cellular towers.
Two additional thoughts
1. Aegean-Blue, I love the the 10" boat radar mount for your Parsec install. It looks rock solid, and is aesthetically great.
2. If you are researching which 7 in 1 4x4 MIMO antenna to get, here is a recent MIRC MIA report with test results on the Parsec Husky, Pepwave Mobility 42G, and the MobileMark.
https://youtu.be/K-I-IdZJg-c Short version of the summary, The Parsec Husky was excellent on single modem routers, but did not perform as well as the other two on dual modem routers.
Thanks again for all the excellent comments and posts.
