Old 08-25-2023, 07:53 AM   #1
2023 27' Flying Cloud
Byron Center , Michigan
TV recommendations
Would like to install a 24" smart TV in our 2023 FC. Looking for recommendations for brands that have same wire connections as provided by AS.
Purchased the Insignia brand but it has a corded plug, not the power port.
2travelers is offline   Reply With Quote
Old 08-25-2023, 08:59 AM   #2
Mollysdad's Avatar
Maybe I'm being a Luddite, but a 'corded plug' is bad?
Old 08-25-2023, 11:11 AM   #3
2019 25' Flying Cloud
Hendersonville , North Carolina
We have a 2019 FC 25 RBT. Both TV's supplied from AS were not Smart TV's. We put a Firestick on each one. Perfect so far. They work so well and offer so much free content that we put Firesticks on our 3 home TV's. Excellent product.
uraljohn is offline   Reply With Quote
Old 08-25-2023, 12:17 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There used to be Insignia TVs with the external power brick (power converter) that stepped down household 120v power to 12vdc power. I installed one of these in the bedroom and was able to to replace the power brick with a 12vdc direct plug-in cord and use the 12v outlet in the bedroom.
For the living room I couldn't find one of these, so I installed an Amazon smart TV which cost about $125. It plugs into an outlet powered by the inverter so we can watch when we're dry camping. Doesn't use much power.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 08-25-2023, 05:32 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Airstream switched to 12v dc TVs, the way Airstream does things it's possible they stopped putting 120v outlets within 6' of the TV.
Old 08-25-2023, 08:22 PM   #6
1994 25' Excella
Another way to do this is to use a very small (but adequately sized) inverter to power the TV. You can buy some very compact inverters intended for use from the cigarette lighter outlet in a car which have enough capacity to run a TV. This can converter any TV into a 12vdc TV.
Richard
11018
Yellowstone / Grand Teton Campground Recommendations JaceBeck On The Road... 13 07-26-2006 09:37 AM
air conditioner recommendations Tin Hut Our Community 11 09-05-2003 04:30 PM
Drain Fitting conversion? Recommendations? Jabba Waste Systems, Tanks & Totes 3 07-11-2003 05:30 PM
shop recommendations in K.C. kc airstreamer Commercial Listings 0 05-18-2003 12:34 AM
de-humidifier recommendations dpope 2000 - 2004 Safari 3 04-07-2003 03:08 PM
