Old 02-03-2023, 11:26 AM   #1
2019 27' Flying Cloud
Oracle , AZ
TV Booster on no channels
2019 Flying Cloud RB, TV booster on and not getting any channels. TV works on dvd , scanned several times. Tried to turn and off booster 50X with no reception. Both front and rear TV's not picking up and reception in several good locations.
Where is the problem. I never did any work on TV, Booster or roof antenna.
thanks
Photobill2 is offline   Reply With Quote
Old 02-03-2023, 12:01 PM   #2
STREMN's Avatar
2008 30' Classic S/O
Hampton Beach , New Hampshire
I'd check the coax connections...road vibrations can loosen things up.
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
STREMN is offline   Reply With Quote
Old 02-03-2023, 12:38 PM   #3
Boxite's Avatar
2008 22' Safari
You may have forgotten (or not known) you have to select antenna or source/cable …and if ant…you must have the little “jumper” across the amplifier installed.
Old 02-03-2023, 02:16 PM   #4
Mollysdad's Avatar
My blame is going onto the lousy roof antenna. I get no channels when I'm under cover but 20 miles from the TV transmitters. Some places you think, "I should get something", but don't.
The booster button has two functions, 1. Boost the off-air signal. 2. Switch to the roof antenna.
That's why you can't boost a cable channel or attach an outdoor antenna to the "cable" port outside.
I suspect the TV is fine. You could try running a 25' piece of coax with "f" connectors from your TV to an outside antenna of some kind, (even out the door, just to test the TV.) check WalMart or Amazon.
BTW beware, there is no such thing as a digital antenna, a HD antenna, an antenna for a 'smart tv'. Or my favorite, a "500 mile antenna" (yeah, maybe on the Moon!")
Old 02-03-2023, 02:42 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Has it ever worked?(during your ownership)
Do you need to raise and aim the antenna you have?
Old 02-03-2023, 05:22 PM   #6
Oracle , AZ
I selected "air" on the TV, then went directly down to the scan. Is that right?
Old 02-03-2023, 05:23 PM   #7
Oracle , AZ
it worked in the past. The newer units don't have an antenna to raise or lower, Thanks
Old 02-03-2023, 08:45 PM   #8
1988 32' Excella
Ok, that makes a bad connection most likely and makes it less likely the problem is on the roof.
I would start checking for bad/loose connections behind the switch for the booster.
Old 02-04-2023, 04:42 AM   #9
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If the red or green light comes on when you turn on the TV antenna at the wall plate and there is no reception, I'd agree that a loose connection is a good possibility.
The wall plate can be pulled forward after removing the screws and then you can check the connections there.
I have had one of the wall plates/power unit fail in the past. They can be found online or in most RV parts houses and are very easy to replace. Turn off the 12v power before doing the replacement. Lots easier/cheaper to start with replacing the wall plate before doing the roof antenna, and it's much more like that the wall plate is the problem since that's where most of the electronics are housed.
Richard
11018
richard5933 is offline   Reply With Quote
Old 02-04-2023, 09:58 AM   #10
2003 28' Classic
Stillwater , Oklahoma
My coax broke last year at the rooftop connection. Reinstalled the cable end and works great now.
ttrout is offline   Reply With Quote
Old 02-04-2023, 01:19 PM   #11
Oracle , AZ
thank you, I'll let you know what I find,
appreciate the input.
Old 02-04-2023, 01:20 PM   #12
Oracle , AZ
this is a 2019 that came with the unit, It worked in the past,
Old 02-04-2023, 01:22 PM   #13
Oracle , AZ
Yes it worked until 2 weeks ago, thank you, I'll let you know what I find,
Old 02-04-2023, 01:24 PM   #14
Oracle , AZ
I'll check on that asap. I guess I will have to get up on the roof. Sounds like a song, LOL
Old 02-04-2023, 01:25 PM   #15
Oracle , AZ
Thanks lots. I wasn't sure where the connections were other than the roof.
Old 02-04-2023, 01:26 PM   #16
Oracle , AZ
will do that next, Thanks
No TV Channels, green booster light not working mdtravelers Audio, Video & TV 17 10-05-2020 03:49 PM
C channels jr3149 Ribs, Skins & Rivets 0 06-03-2010 02:41 PM
Best sealant for exterior window channels? acltaos Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 05-26-2009 01:46 PM
Why do channels fade away? Phantom Audio, Video & TV 19 01-18-2009 06:31 PM
Local channels question for Directv Sovereign86 Computers, Internet & Satellite 11 08-26-2008 07:58 AM
